Old 12-05-2017, 12:12 AM
First the 30" transom, it would get the top of the transom plus the splash well drains five inches higher and the engine power head that much higher out of the water. I've seen the 30" transom on quite a few and I iked it.
The fiberglass re-bar is just over kill, which I like, and thought it would be a nice addition. Rest assured the Arjay will stick to the re-bar. I don't put too much thought into such big words that start with homo. Above my pay scale.
Old 12-05-2017, 07:48 AM
Why do you feel this is necessary to add fiberglass rebar? Is Arjay not structurally sufficient? Were you not happy with the rigidity of the transom? Would Arjay bond to the fiberglass rebar to make a composite? Or would it create a cold joint and weaken the homogenious Arjay pour? Very curious...because I'm leaning toward this method of rebuilding my transom and have heard you speak about the fiberglass rebar concept before but never really had a chance to discuss it thoroughly with you.
Thanks,
Jim
My guess is peace of mind!
Old 12-05-2017, 09:56 AM
FLexpat FLexpat is offline
Please excuse me while I geek out here, just adding confusion of engineered structures without all the equations and tensile diagrams…
Rebar in concrete is for strength in tension because concrete is weak in tension but strong in compression. When it is in the middle of a concrete slab it really doesn’t help for flex. When a piece of concrete is designed for flex the rebar will be on the outer part, maybe an inch inside the concrete to protect it from the weather etc. That is why you see ‘cages’ of rebar in poured concrete columns.
A similar concept applies to reinforcing a pourable transom. The glass is there for tensile strength and should be on the outer edges; in the middle it just flexes. This is why a slab of Coosa just has a thin layer of glass embedded in both outer edges, not the middle (you can see it if you cut a piece).
A modern transom is cored construction with very high compressive strength (to keep bolts from crushing the core). The Elements of Boat Strength by Gerr has a very good discussion of cored construction – it is worth the read.
You can do what you want, but if I was doing this project I would lay up strong skins (scarfed to the old skins and finished smooth) around a temporary form of a core, pull the temp core and then pour Seacast in. A couple of additional layers of 1808 or 1708 could be added to the inside of the skins (covering the joint by about 3-4 inches) after the form was pulled. That way you would get a transom with construction similar to Coosa without having to completely remove one skin. Use peel ply on the layups. Since Seacrafts like the motor to run a bit high, I would make it either 26 or 31 inches, depending on what motor I was using.
Like others have said, practice on another part first; you don't want to realize you made a mistake by looking back at where the engine used to be. Good luck.
Old 12-05-2017, 10:20 AM
Eric B Eric B is offline
Rybones,
I went to from 24" to 30" on my Sceptre based on strong recommendations from Ken (Kmoose). I love it! Keeps the motor obviously higher out of the water and lets it keep breathing in reverse
Old 12-05-2017, 10:47 AM
Rybones Rybones is offline
Thanks All, now we are cooking with gas. Why do we want to lay up to the outside first/primarily and then to the inside? I figured there would be greater streanth (perhaps only maginaly) laying up the glass from the inside first. Also, I'm still trying to get my head around this 30" (or 31") inch transom thing. Wont 30" affect the overall ride greatly as I am currently at 20" and eleminating most ability to reverse? (I currently have a 25" shaft (insert joke here) and also have a hydraulic JackPlate with 5" of travel and 5.5" of setback). As it stands, my boat gets out of the hole instantly and I have a top-end of 45 plus it rides really nicely. I can see raising 5" or 6" but 30" or so is a 10" incrase that makes me think it will have a great affect on my hols-shot and ride. Please let me know the impact of going 30" and why, plus if it affects my rigging.
Old 12-05-2017, 11:34 AM
Is porable transom a vaible option if done properly and bonded to new and old glass?
I would say its a viable option and would work if done right but me personally I wouldn't use it to raise a transom. I think what Flexpat says is the best word of advise. Long as you have the proper layups on each side you will be ok long as the core has the compressive strength for hardware. Make sure it is grafted to the old glass well. 12 to 1 and blend it in a ways with the inner and outer skins. I could see where this product would work well to fill voids vs cutting something open but I like the idea of wood or composite (dense enough) for transom cores. Especially if my motor is hanging off it or a bracket. There are a lot of loads from the outboard. Also just curious? What dose this stuff weigh? A 5 inch extension probably not so much but a full transom poured with this stuff would weigh a lot I would think.
Edit:
I really don't know much about these type of pourable products or have used them so I really shouldn't comment about them at all anyways. Those who have researched them and used it will tell you better than I. I would worry it could crack but with the technology today it may be a good product.
Old 12-05-2017, 12:00 PM
The 30" transom does not affect the hole shot at all. with my set up and tabs all the way down I am on a plane at 11 knots. A normal hole shot is very quick and clean. here are some pics of the finished transom, how it sits in the water and how it rides on a plane.
Old 12-06-2017, 10:05 PM
I looked in to the weight of seacast, it is lighter than pywood and a little heavier than Coosa. I dont know what the weight of Arjay or Nida is, but I assume it is comperable.
Old 12-06-2017, 10:34 PM
Eric B, that is a gorgeous Sceptre you have. A friend growing up had the same boat/color but his was an I/O. It rode very nicely and was a great fishing boat but a little on the slow side. It doesnt look like you have that problem. Although my 20 and your 23 have a similar hull design, the dimensions are very different. So transom height, ride and reversablity would also be very different, COG between those 2 boats is very different and you have a 300 hanging on there compared to my 2stroke 150. I have seen a 20 in the keys with a 300 on it. Wonder that thats like.
Old 12-07-2017, 09:38 AM
A 26" transom would be good for a 25" shaft mounted on the transom and a 31" transom would be good for a 30" shaft ; this is to get the AV plats somewhere between 1 and 2 inches above the bottom of the V. If you have a jack plate with 5" setback you could probably go a couple of inches above that.
Laying glass can really be done from either side - I would probably do it like I described because it seems easier for me to get a good finish - that said, I don't know your exact transom arrangement or skillset with fiberglass and resin. I consider myself to be a learner with a long way to go in that area. The big thing is to make sure the inside skin can handle a lot of tensile loads that come with an outboard hanging on it - especially with a jackplate which gives it a bigger lever.
Also - plywood weights: Okoume and Meranti (I think Lloyds certified too) are both pretty close to 26lbs/ft3 like Coosa Bluewater 26 and unspecified 'marine' plywood is more like 30-35 lbs/ft3.
