Old 07-11-2018, 11:08 AM
Oldboat Oldboat is offline
Default Old boat trim tab questions
I want to install electric trim tabs . Have built a 30 inch Armstrong for a 300 Yamaha and will this week draw out on Transom the location it will sit to check trim tab clearance .does anyone have this setup with recommendations on there tabs will help me to move on. Thx
Old 07-11-2018, 11:33 AM
You are going to have limited clearance with the bracket. This will require edge mount tabs that don't have as much throw. Go with the biggest tabs you can fit. I ended up with 12x12 and still wish I had more tab.
Old 07-11-2018, 11:44 AM
Default Trim tabs
That’s good info. Do you no if the edge mount will require a full bolt with nut or just screw in.
Old 07-11-2018, 12:54 PM
Default Trim tabs kmoose
Thx you nailed it .
Old 07-11-2018, 01:02 PM
Default Ollboat trim tab
I think if I go with the 12X18 lenco I will thru bolt. I still have option decks are not glassed in yet. That’s a lot of pressure with that big of plate
Old 07-11-2018, 01:43 PM
Go with the 12 x 12 Bennett Bolts. They will mount just under 10" up your 13 degree transom, see post #43 below link. We mounted a 27" bracket just above the top of the trim tab's bracket, about 3/8". No notching the bracket, worked perfect for a 25" shaft eTec G2. No thru bolt, just screws and 5200.
http://www.classicseacraft.com/commu...844#post258844
Oh yeah, the Bolts are very quick and responsive!!!
Old 07-11-2018, 03:55 PM
Default Old boat trim tabs
Thx the bolts look good. Based on the Armstrong spec measuring up 28 inch 72 inch wide and back down 2 inch for bracket it looks like I have a little more than 12 inch to work with so they would have plenty of room. That is mounting past last chime all the way outside. About 3 inch from outside
Default Bennett Bolts
Hey Don- thought I read somewhere that an advantage of the hydraulic tabs is they stopped immediately whereas there was some overtravel with the electric tabs. Maybe not for the Bennett Bolts. What is your conclusion? Thx
Old 07-11-2018, 07:41 PM
Hey "T", I'm not sure about that. It's my brother's boat and he's REAL happy with them so far, plus I never had issues with "overtravel" with the Lencos I had on my Pathfinder.....just had to replace them too often, while my hydraulic Bennett's are still going after 40 years.
