  #41
Old 09-24-2018, 12:35 PM
Tashmoo2 Tashmoo2 is offline
Default 1973 rebuild
Hi Oldboat,
Great boat. We had a 71 IO.
Did you buy or build the hatch receivers? I am debating the make or buy decision because I have not found any that match the dimensions I need.
Best regards,
Ed
Old 09-24-2018, 01:06 PM
Oldboat Oldboat is offline
I bought both hatchs complete from gulf stream and I am very happy with them. They feel very solid in my 1 inch coosa decks. well worth the cost if u calculate time and materiel to build and another thing done on the forever list.
Old 09-29-2018, 12:41 PM
Got the coosa decks glass down finishing tabbing to start glassing deck surface
Old 09-29-2018, 03:21 PM
SeaPlusPlus SeaPlusPlus is offline
Looking good! I'm sure that deck is solid as hell.
Old 09-29-2018, 03:48 PM
Real happy with it.its like a brick even with no glass either side yet. What I found is that the coosa without glass stay really flat and strait so I put a lot of work into getting every thing level so when I glassed in the boards they would align perfectly without putting weight or shims anywhere ,just put my epoxy (mix butter) thick so no gaps and a really nice level deck and just lay them in there. I saw a guy put battery’s and thing on his and it was very wavy uneven. I think I just got lucky for I never did this before.
Old 09-30-2018, 12:15 PM
Cracked open another roll of 1708 (115 pounds) . Starting to cut first layer of 1708. The second layer will go up the side to were grinding stops. Hot out the s morning .
Old 09-30-2018, 08:45 PM
I've never used the coosa without both sides glassed with 1708, however I can't see why it would not be very strong glassed on just the top like you are doing! Since there is less than 1% water absorbstion with the coosa, waht's the difference if the bottom is not glassed?? When you get it tabbed to the sides it will be very strong!!! Good luck!!
Old 10-01-2018, 07:42 AM
I didn't put any glass on the underside of mine either. Solid as a rock! I kept reminding myself of the 2 layers of continuous strand made into the board.
Old 10-01-2018, 08:00 AM
I’m not to worried about it .
Old 10-01-2018, 08:31 AM
Yeah I wouldn't be either. Here is a guy who submerged a scrap piece of Coosa for 5 years. Not a very scientific test, just soaking a scrap piece in tap water, but still has some merit for absorption rates. To quote someone from that thread:
Originally Posted by midcap
3/4" 26 coosa is 52 lbs a sheet normal transom uses two sheets, so 104lbs, let's say that transom is 80% of those sheets. 82lbs.
Soaking the complete sheet then would add 7lbs. That's not even one gallon of water.
Personally I would have put a layer of 1708 on the bottom, but only because it would nag at me that I had a chance to over engineer something and didn't. But, that floor is definitely going to outlast all of us, looking great!
