Old 09-29-2018, 01:19 PM
Default Cleaning gas tank
We all have read what ethanol gas does to the inside of the tank cleaning and send it downstream
Now my question could I not buy a few gallons of e85 and pour it into a empty tank and let it work its magic and clean the tank?
Old 09-29-2018, 02:24 PM
I'm very interested in responses to this as well. Currently have my tanks out of the boat (1978 23' Sceptre I/O) replacing all hoses, etc. and was thinking of putting approx. 5-10 gallons of acetone in each, and slowly rotating the tanks to let it work on each panel.
Old 09-29-2018, 03:20 PM
SeaPlusPlus SeaPlusPlus is offline
About to pull the tank on my 23. Assuming it's in good condition I'm interested this as well. Idea sounds good to me!
Old 10-09-2018, 07:30 AM
The last tank I cleaned I ended up cutting access holes into the top of it to get the varnish out. What I found that worked well was seafoam, I wet a rag and coated the inside walls. Once it sat and soaked in after a few minutes it loosened up the varnish where it wiped right off. You may be able to fill the tank with a bottle or two and soak it then shake to get most of it out but I have found that the only way to fully clean one is to get you hand in it to wipe all areas.
http://www.classicseacraft.com/commu...ad.php?t=29477
