Old 05-01-2019, 03:22 PM
bigi bigi is offline
Default Under Deck Livewell solutions
I'm refitting a Sceptre. The under deck livewell has no pump. Just a drain through the transom under the waterline. The through hull fitting is shot. I need to decide whether to replace it and add a seacock or glass it in and let the well drain into the bilge. Of course it wouldn't be used as a livewell in that configuration. Can the hatch be made to be water tight?
What solutions have you all tried?
Thanks!
Old 05-02-2019, 12:37 PM
mikeyk mikeyk is offline
While my situation is almost the same as yours (my 3/4" thru transom drain still theoretically works), I am not satisfied at the time and effort it takes to empty the livewell. I have another boat - not SeaCraft- that I fish commercially and it has a 150 gal. livewell. It fills, and drains, through the bottom of the hull. While these dimensions are overkill for our SeaCraft livewells, this should give you an idea of what I did: I hole-sawed thru the bottom of the hull just ahead of the rear bulkhead. The hole was just big enough to epoxy in a 3" PVC pipe ring. On the underside I attached a v-shaped fiberglass scupper tapered about 3 1/2" to 4 1/2" front to rear. It's about 1 1/2" deep at the rear outlet. Outlet dimension is not critical as long as it is not less that area of the PVC pipe. To seal the hole I used a plastic 3" pipe plug which I had replaced the stock carriage bolt and wingnut with stainless. On a plane, I can drain 150 gal. in about 2 minutes. Water moving past the scupper creates a venturi effect to drain the livewell.
I 'm sure something like 1 1/2" would be adequate for the SeaCraft livewell.
Thanks!
Old 05-03-2019, 09:45 PM
I made a dry well...let the live well drain into that...have a bilge pump in the dry well and let it pump the excess over board.
Old 05-04-2019, 07:03 PM
[QUOTE=bigi;263323]I'm refitting a Sceptre. The under deck livewell has no pump. Just a drain through the transom under the waterline. The through hull fitting is shot. I need to decide whether to replace it and add a seacock or glass it in and let the well drain into the bilge. Of course it wouldn't be used as a livewell in that configuration. Can the hatch be made to be water tight?
I cut my in deck live well out.
This allowed me to plumb an above deck live well under deck.
3/4 clamshell w rule 800 intake on top and 2 3/8 drain out the transom.
35 gal LW under the LP and she loves the weight there.
Old 05-05-2019, 04:01 PM
Default Great ideas
Thanks for the ideas!
