  #181
Old 09-14-2019, 06:04 PM
Kraken Kraken is offline
The hurricanes and work have kept me from finishing her up. Last weekend I did 20 hours of wiring and I’m almost done with the electrical. Just an anchor light an horn left. I used the guides from newwire.com to get started.
Has anyone insured a rebuilt Seacraft? Progressive maximum is $40k and Geico is $30k. What’s the best way to cover this boat?
Old 09-16-2019, 09:07 PM
Boat US. $43,000
Old 09-20-2019, 10:18 AM
going to try and get some numbers today. The wind is blowing big time but this is the only day I can do it. I think the motor is mounted a little high. It suck air in corners and in rough seas. Cav plate looks about perfect but may try to lower one hole. Mike set me up with a 3/16/21.5 prop. It is barely on plane at 3000 rpms. It gets out of the water fine and does 47mpg at WOT. I need some fuel efficiency number today. My goal is not top end but good fuel economy.
Old 09-20-2019, 03:26 PM
Are you trimmed down in the turns and rough seas? I have to trim down in tight turns and rough seas.
Old 09-20-2019, 04:14 PM
Don't move the motor! Bite the bullet and go pick you up a standard Mercury Bravo 1 22p. You can buy me dinner later.
Old 09-29-2019, 11:26 PM
Got her in the water to take some numbers. I decided to program the Bennett Auto Trim Tabs first. My son and I got the tabs programmed without a problem. We made a few trial starts and stops to check them when they died. The leds got dimmer and then everything stopped.
Then we took numbers that will most likely be a little better with proper tabbing. The tabs were partly deployed to maybe 10 degrees.
Here is the wide open throttle and max fuel economy. 45 mph @ 5300 rpms @ 1.9 mpg. Definitely slower than I thought I’d get.
I think I can do a little better on burn. 26 mph @ 3400 rpms @ 3.6 mpg.
Kmoose - Should I be looking at the 3 or 4 blade Bravo in what diameter? Will it help with cavitation in heaven seas and cornering?
Later in the weekend, The tabs were fixed, just a bad crimp. I hope the auto tabs are worth the money and effort.
Also as a side note... the Simrad NSS is awesome! I’m still trying to program it also. Trying to set up the 2 fuel tanks with the fluid level sensors. Shouldn’t be hard.
Old 10-12-2019, 01:17 PM
Just put my old trailer on CL Trailer
Old 10-16-2019, 09:47 AM
https://www.ebay.com/itm/Mercury-Mer...AAAOSwOzZZcRlW
Old 11-27-2019, 10:16 PM
Her she is.
Old 11-30-2019, 04:49 PM
Looking good!
