Old 11-15-2019, 05:21 PM
Default Console Layout
I'm starting to get my console played out.
Planing to go with the following
Garmin 94sv GPS/Fish Finder
Standard Horizon GX1300 VHF
Fusion RA70 Stereo
A tach, Gas gauge, Volt meter.
A switch panel with Bocatech switches and a 12voly plug.
My question is how many switches will I need?
I have 2 bilge pumps, 1 baitwell pump, that needs to connect.
I know I need 1 nav lights, and I want some under the gunnel lighting and 1 for the future t-top lights.
How many do I really need with not going overboard?
Is 8 enough?
Old 11-16-2019, 09:04 AM
How many loads do you want switched and how many loads do you want wired to a fuse panel?
I'm restoring an old Whaler and just pre-wired the console while it was out of the boat. I elected to only have 3 switched loads and with one spare; Nav lights, Courtesy lights, manual bilge pump. 12V outlet, GPS, Stereo will be to fuse panel.
Old 11-16-2019, 09:06 PM
You might want one for a wash down pump or even
locker lights ? (every compartment has a light) ...
Two that I have on "Bones" that are used on a regular basis.
Here are before and after on my Seafari project currently underway..
Before:
After:
LED backlit from "Bonestech" ...
NoBones stable mate "No Intention" ...
Old 11-17-2019, 01:10 PM
Tarpun Tarpun is offline
Bad Azz
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
Old 11-18-2019, 09:46 AM
Nice job
Old 11-22-2019, 07:21 PM
Chrismacholz Chrismacholz is offline
I just had this panel made up, to give you some ideas...
Old 11-23-2019, 10:52 AM
I like it!!!
I sent you a PM for additional info from you
Old 11-25-2019, 05:51 PM
So here's what I'm initially thinking
1 Garmin 94 sv in the middle
Standard Horizon vhf to the left
Fusion stereo under the vhf
To the right goes the tach fuel volt and water temp gauges
Underneath goes the panel with 8 switches a 12 volt power suppy and USB port
Would like to go with Bocatech switches but have not made up my mind or the budget
Old 11-26-2019, 05:09 PM
I like it!!!
Didn't see a PM come through.
I like your new layout. Wondering about the VHF over the fusion radio... the mic wire may hang over the fusion a bit.. I'm having trouble figuring out where to put mine.
Old 11-26-2019, 07:31 PM
It’s just to see the best layout but I see what you mean about the mic Cord hanging over the stereo.
Resent the pm but where did you order the panel?
