  #71
Old 05-28-2020, 10:06 AM
JBASS02 JBASS02 is offline
Thanks. I used Total Boat bilge paint, it is working but is taking much longer than advertised to harden up. Since applying I've read a few threads of people complaining the same thing. Next time I'll try something else.
Old 06-05-2020, 10:49 AM
Quick update.
Front deck is glassed and fuel tank is in. I'm hoping to get the underside of the main deck glassed this weekend and paint the remaining lockers. I made a gutter mold and did a small tested(my first time using a mold). Since making the mold I saw a gutter design I like more so I'm scraping the current one and make a new one(out of mdf this time).
Old 06-07-2020, 11:32 AM
Cool stuff...are making some gutters or hatches with that router?
Old 06-08-2020, 10:29 AM
I'm going to make both. I redid the gutter this weekend, here is V2. The corners now have different radius's and a flat spot was added for a center drain.
Old 06-08-2020, 10:36 AM
The first layer of paint is on the three deck lockers, and the underside of the main deck is glassed.
Old 07-06-2020, 11:39 AM
Gutters are in and all the below deck wiring and fuel lines are attached. Hopefully I'll have the deck permanently in this week or weekend. If I get the chance I'm going to glass the cooler compartment this week too.
Old 07-06-2020, 11:45 AM
Does anyone have a good way to remove the mold release wax from gutters? I've heard lacquer thinner works but it wasn't from a reliable source.
Old 07-06-2020, 06:36 PM
They make a dedicated wax/grease remover but lacquer thinner prolly work just fine. Good sanding and water bead test after to make sure...
Old 07-07-2020, 09:42 AM
warm water soap and scrub then sand...as your gonna prime those anyways...I like using duratec as the first step prior to lay up as it's much easier to get the wax off that then from inside the fiberglass pores...nice hatches your moving right along
Old 07-09-2020, 11:02 AM
Thanks. Looks like the deck will be permanently attached Sunday.
