Old 07-28-2020, 09:56 PM
Originally Posted by hobiepilot View Post
What do you guys recommend for bottom paint on these center consoles? The boat will be trailered. Above the water line will be Awl Grip Aqua Mist and something White below the water line.
Got pics?
Old 08-01-2020, 09:09 PM
hobiepilot hobiepilot is offline
Some more progress. Stuck the deck down and fiberglassed it in place. Then did the first layer of filler. Progress is fast now as everything we do is putting something back into the boat. Lots of sanding and filling ahead! A few more things getting built right now are boxes to cover up the fuel fill and washdown hosepipe, as well as some rod holders to add structure under the gunwhales. I'll throw up some more pics when they are done and installed.
Cap Filled, sanding then a thin layer of glass to prevent pressure cracks next
Building out the hatch lid support on the transom boxes.
Old 08-02-2020, 09:36 AM
Clamp envy!
Old 08-14-2020, 07:53 PM
First coat of Filler went on today after I cleaned up the fiberglass around the rod holders and the fuel line/washdown boxes. now its sanding and filling and sanding and filling.
Old 08-14-2020, 08:59 PM
I like your under gunnel rod holders..I was going to fix your images but looks like I'd have to remove them all then re add them from my computer which is more pics then I want to mess with...are you taking photos with your phone and then posting? Nice work
Old 08-14-2020, 09:37 PM
Yeah I am taking them with my phone, I've tried all sorts of things to try and make them go right way up! nothing seems to work.
Old 08-16-2020, 08:13 PM
Drilled and dry fit the hardware on the deck today. Exciting to see them on there even though they were pulled off right away. We also had 4 flush mount rod holders we planned to install on the caps, but realized they would interfere with the horizontal rod storage and essentially make them useless, so we made the decision that the horizontal storage was more important and scrapped the flush mount rod holders and kept the cap clean. We have 4 rod holders on the leaning post and for the amount of fishing we plan to do that will be plenty.
Attachment 22145
Attachment 22147
Attachment 22148
Old 08-24-2020, 07:28 PM
Awesome!!!!
Old 10-06-2020, 09:44 PM
Heres an update on the last couple of weeks of work
Installed the boxes on either side of the boat. The Port Side will have a fresh water wash-down hose.
The Starboard side is a box around the fuel fill and vent pipes. the cover will be removable to get in there to take care of any issues that might arise.
Finally got the first coat of 545 primer down. Was pretty happy with how it's looking so far.
The Primer shows all the dings and blemishes, vinylester filler all over the place. I finished fairing this filler today and will putting down a coat of High Build Primer next.
Old 10-07-2020, 07:25 PM
Looks amazing!!!! Solid work!
