  #71
Old 12-03-2020, 11:59 AM
Etecs don't have oil pressure
You sure? I thought they injected the oil in specific areas of the engine and it's not all mixed with the gas. It may not be high pressure like the fuel injectors, however I would think the oil has to be under some pressure. I'll ask my brother how/if his 250HO registers that info on his MFD. Again this is from memory that a BRP dealer/salesman told me at a boat show....I've burnt a bunch of brain cells since then.
Old 12-03-2020, 12:03 PM
steel686 steel686 is offline
That’s a good point. Just low oil on BRP gage. Only wondering what information EMM drop cable is sending.
Old 12-03-2020, 02:40 PM
jtharmo jtharmo is offline
E-Tec's have an oil pump with an integrated pressure sensor but it isn't a constraint pressure pump like in a 4-stroke. They use pulses to push oil to points around the engine I assume in coordination with inputs like rpm, fuel flow, etc. I think the oil alarm is linked to rate of actual pulses compared to what the EMM wants. So in a long winded way, I'm saying real-time oil pressure on an E-tec isn't very helpful.
Old 12-03-2020, 03:06 PM
FLexpat FLexpat is offline
I thought the BRP gauge light was for low oil level switch on the reservoir but it could be a pressure indicator. I know I would want a true level indicator (not switch) on the oil tank but I'm kinda picky. It is pretty easy to add NMEA sensors to the backbone.
Old 12-03-2020, 04:54 PM
The sending units on my oil and fuel tanks are both NMEA 2000. I can see levels in both tanks on I-Command or Garmin independent of the E-tec's EMM output. I definitely like to see the oil level.
Old 12-03-2020, 06:01 PM
Bill. Do you have an analog fuel gage as well? Any trick to wiring both? I guess I need a few more drops and do a little reading. Want to see trim first but fuel and oil levels would be nice to have on one screen.
Old 12-05-2020, 01:23 PM
The only analog gage I have is water pressure. Everything else is setup on I-Command gages and I can see most everything on my Garmin as well. The sending units are both WEMA with only a NMEA cable output. I bought the boat with them but it’s a pretty basic setup with tee’s going into the network backbone. The sending units need to be calibrated after the network finds the new devises. I just used empty, half and full tanks. They have been reliable and as accurate as I need.
