Old 03-08-2021, 10:42 PM
Originally Posted by take a potter View Post
One thing that I might add for transom mounts, is to put them on a mounting block 1" thick. Keep the bottom edge of the block above the bottom of the hull by 1". This allows the transducer to sit a little further behind the hull and therefore it can get in cleaner water as the water rises off the hull. Doing so helped me have a clear image up to about 30kts.
I didn't know that!
I mount mine on a G10 block that I adhere to the transom with 3M 5200 so that I screw into the block, not into the transom, which helps with transom life.
Also, kudos to Fr. Frank for the transducer tutorial!
Old 03-17-2021, 12:55 PM
HatTrick HatTrick is offline
Fishstretcher, It looks as though G10 is expensive. I am correct? Are there any other materials you have used will work for the transducer block?
'86 20 ft CC with 4-stroke 150 yamaha
Old 04-09-2021, 09:19 AM
jsylvester08 jsylvester08 is offline
Default Finally with pictures.
Thanks all for the help finally dragged her home and exited for the weather to get warmer here in Long Island. Here are a few pictures. I’m wondering from looking at Frank’s if it’s sitting down too close to the engine wash. Any help would BGE appreciated. Also does 5200 hold all season? I would love to not add anymore holes into a 35 year old transom.
Old 04-09-2021, 04:43 PM
Wow, how can that NOT be working?
Old 04-09-2021, 09:48 PM
Default Also disregard the barnacles
Bump are you serious or are you kidding? Obviously disregard those barnacles I’ll knock them off. 2nd anything I can put on it to prevent them from growing on the transducer?
Old 04-10-2021, 12:20 PM
Actually, I thought you were kidding when I saw the picture. Take all that junk off and move it further away from motor,or just take all the stuff off first and try that. Then go with moving it if that doesn’t solve the problem.
