Old 05-16-2021, 07:19 PM
abl1111 abl1111 is offline
Default 23 Palm Beach
I know I know its a Classic SC website, but you guys know your shitake mushrooms !
My brother bought a 2006 Palm Beach a few years ago - it has a new fuel tank in 2017 - pre, my brother ( so the floor was pulled and a new 100 gallon tank with all new hoses, installed ).
Last year there was no fuel smell - this year a fuel smell in the bilge.
If we remove the fuel fill hose, the overfill hose and the fuel line to test - and all tests ok, is it safe to assume that the tank is leaking ?
Hard to believe a 2017 tank could leak but, for all I know the tank was re-bed in foam ( the boat is OEM made with foam, I believe ) and galvanic corrosion has done the dirty.
Thoughts and thx. Not a SC, but a poorly made clone. Boat rides great - they're just made really poorly.
Old 05-17-2021, 06:57 AM
Check the sending unit gasket also. Mine leaked.
Old 05-17-2021, 07:15 PM
Do a pressure test on the tank.... Could be a cracked weld on a seam..
3 lbs. max on the test. Also Dawn soap at the ready to drip on every seam and seal.
Old 05-18-2021, 09:01 PM
Sending unit gasket inspected and ok
Tank is under deck - no access other than small inspection plate. Planning on testing the hoses and tank.
Stay tuned
