Old 07-26-2021, 04:08 PM
72potter20 72potter20 is offline
So your motor is on the transom and your cav plate is 2" above the keel.
I'm getting a custom 17" setback bracket made and I was going to install it so that the lowest height of the motor would put my cav plate about 2" above the keel now I'm thinking I should go more...
Old 07-28-2021, 09:12 AM
deerfly deerfly is offline
yeah, based on my setup I think you have some latitude to go up and inch or three. As you probably know prop design a big factor too so experimentation is key. Also, I would start high so if you have to patch holes in the transom most will be above the waterline
