  #61
Old 06-07-2021, 10:35 AM
This boat is going to be real nice! Never been a fan of round washers for brackets..maybe you doubled them up? have had welders cut some 1/4 inch square washers in the past...Nice work and thanks for documenting here on CSC !
Old 06-08-2021, 07:51 AM
PackRat PackRat is offline
Thanks for comment. Hermco provided fender washers for the bolts. 1/16” thk on bracket side and 1/8” thk for transom side. From 1/4” thick min hatch cut out scraps from deck laminate I cut 2” diameter washers and used them plus thick fender washers on all bolts inside the transom except 2 that were tight clearance to battery shelves. Will take a pic next time at boat..
I assume you like the square just for more area?
Old 06-08-2021, 10:51 AM
Yea a lot stronger. You cant build a house over here in earthquake land without them. At least thats what I was told a long time ago...
Old 08-02-2021, 07:00 AM
Pipe work is done and pretty happy with result. Working on finish painting the hard top and adding hardware. Motor installed soon.
Old 10-09-2021, 07:31 AM
Finally was able to get engine installed , 300 Suzuki duo-prop, and get in the water to see how the balance worked out. No numbers to report yet as in break- in period. Felt slightly stern heavy which is good as no gear, chairs, tackle or anchor gear forward. Think is will balance out pretty well when all loaded up. Still finish work to do in cabin, deck non- skid but looking forward to next season.
Old 10-09-2021, 09:13 AM
FLexpat FLexpat is offline
That looks GREAT!!!
Old 10-09-2021, 11:23 AM
Nice looking boat sits perfect...You nailed it!
Old 10-11-2021, 07:09 AM
That looks awesome! Great job!
Old 10-11-2021, 11:37 AM
Let us see some Teak on that helm station & the"Gucci Stamp" will definitely be in order! Great job sir.....
Old 10-11-2021, 12:26 PM
x2! Nice disposition
