Old 08-24-2022, 09:26 AM
Default Transom
https://www.thehulltruth.com/boats-s...r-console.html DOES THIS LOOK LIKE A FACTORY TRANSOM SET UP FOR A 74 CENTER CONSOLE. SINCE I POSTED HIS ADD WHAT DO YALL THINK GOOD AND BAD?
Old 08-24-2022, 12:18 PM
No, looks like they added a top to the splash well and made a bench seat on a o/b boat and closed the transom in. It doesn’t look like an i/o transom.
Old 08-24-2022, 12:41 PM
Would that stop you from making a offer on it?
Old 08-24-2022, 01:01 PM
Not one bit for myself, I like bracketed boats that are thought out well & if the work is good the work is good. Typically buying it with the work already done is cheaper than paying to have the work done. Pay the $$$ for a survey if ya like what ya see.
Old 08-24-2022, 01:05 PM
thanks
Old 08-25-2022, 10:16 PM
I have a 73 cc that was an I/O. That transom looks just like mine with the arch to it.most guys don’t do the arch if it was an o/b as it’s a lot easier to make it flat across the back than doing all the extra work getting the curve right. The bilge hatch width is about right for the I/O as well. I like what we can see of the work they did with the transom seat as well took a lot more effort to put in the toe recess at the bottom of it along with recessing it into the transom cap for added room
Old 08-25-2022, 11:59 PM
FLexpat FLexpat is offline
X2 on it probably being from an I/O and appearing to be a well thought out concept.
Old 08-26-2022, 07:14 AM
It was a 3/4 restore. Here's the goods.
http://www.classicseacraft.com/commu...ight=fullhouse
Old 08-26-2022, 07:15 AM
I KNEW I remembered this! This is the member I was referring to.
Old 08-26-2022, 07:44 AM
Thanks looks like it had alot of work that appears to have been done well. What do you think? Thanks for sharing. Gives a better insite to the boat.
