Old 02-13-2003, 10:44 AM
Briguy Briguy is offline
Default New Evenrude unvieled at Miami
Does anyone know more about the Evinrude line of E-Tec outboards introduced yesterday at the Miami boat show?
http://www.evinrude.com/evinrude/e-tec/photography.htm
Here is the link:
Capt. Brian
Old 02-13-2003, 11:02 PM
tangofniro tangofniro is offline
Default Re: New Evenrude unvieled at Miami
Briguy are you going to try to make it to the show this weekend?
Old 02-15-2003, 10:03 AM
No, I will not be able to make it. I did Ft. Lauderdale.
Capt. Brian
Old 03-08-2003, 09:55 AM
barnacle barnacle is offline
The Evinrude E-Tec Engines are a DI Two Stroke. It uses 50% less oil then current DI engines and 75% less then current carb. 2 strokes. To get this oil savings e-tec oil must be used along with a EMM that a dealer must program to let it know its using e-tec oil. THe E-tec also puts out 80% less carbon monoxide at idle then current 4 stroke outboards. It is also whisper-quiet thru out the rpm range. With fully-stratified fuel burn you get start up within one revolution. The 90 e-tec is is 100 lbs lighter then the current 4 strokes in the same hp. range. Plus the engine has such heavy duty parts along with tight tolerance's there is no break in. Full speed out of the box. The smaller ones will be out around July and the Bigger ones by 2005.
Old 03-08-2003, 04:22 PM
Im tempted to wait for the 250, I wonder what they will cost?
Old 03-09-2003, 08:56 PM
Thanks for the great info Joe. How are they able to shave off 100lbs from a 90 hp 4 stroke. I assume you would be talking sub 300lb range which is back to the old carbed motor weights. Look forward to any other info you could give us on these "super green" motors.
Capt. Brian
