Old 03-10-2005, 09:16 AM
abl1111 abl1111 is offline
Default Swim platform installation ?
I will be installing a full-transom, teak swim platform on my 23'Tsunami w/ an I/O ( possible fishing obstacle, but it will allow the wife to get on and off when we 'beach it' ).
It's roughly 21"-22" wide by 6.5'- 7' long. I will be using (4) AFI S.S. brackets - these are solid, triangle shaped.
How high above the water line should I mount this ? Is there a try-true method I should know about before I start drilling holes in my beautiful, new transom ?
I was thinking of oversize drilling the holes and then re-filling w/ epoxy and re-drilling to avoid any water intrusion.
Any input ?
Thx,
Alan
Old 03-10-2005, 09:48 AM
TUGBOAT TUGBOAT is offline
Default Re: Swim platform installation ?
Depends on how much You've done to Her. I'd probably to be safe. Launch Her go to the stern grease mark it & Go from there. I added a lot of weight to mine on the rebuild.If I left it where it originally was It woulda slapped the water & Skeered the YellerTails away !??? Hate drill'n dem' Holes in the Transom too!
Tug [img]/images/graemlins/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 03-10-2005, 12:40 PM
gw204 gw204 is offline
Make sure you mount it high enough to allow you to tilt the outdrive all the way up.
Brian
1981 Mako 17
Old 03-10-2005, 05:38 PM
Alan
A lot holes and maintence with a teak platform [img]/images/graemlins/shocked.gif[/img]
Whats wrong with a Armstrong Ladder. Easier to board than a platform. Easier to install. Stainless Steel has no maintence [img]/images/graemlins/wink.gif[/img]
Armstrong Ladder
Old 03-10-2005, 06:45 PM
warthog5 warthog5 is offline
Your on the right track. [img]/images/graemlins/smile.gif[/img]
I use this methiod for composite or plywood core.
http://bertram31.com/proj/tips/sleeving.htm
Old 03-14-2005, 11:13 PM
Thx for the responses. I was not thinking of using a pc of PVC though. I was just going to drill oversize thru-bolt holes ( excluding the gelcoat skin - I'd leave that the correct bolt diameter ) - then fill with epoxy/cabosil mix, tape both ends - let cure.
Then drill through the cured epoxy w/ one of those centering jigs/tool for the drill - to assure a straight hole. Then mount all and use BoatLife to water proof it up. What do you guys think ?
alan
