Old 03-24-2007, 03:00 AM
SCSeacraft SCSeacraft is offline
Default Overkill is the only way to go
5700 GPH should be enough on the bilge pumps.
If only the boys on the Titanic had planned so well......
Old 03-24-2007, 08:04 AM
Default Re: Overkill is the only way to go
You can never have enough suction thats for sure. Tell me about that vent you have there. Is it plastic or metal? and if metal were can I get 4 of them?
Old 03-24-2007, 08:12 AM
wavelength wavelength is offline
water OUT is good.
70% of the earths surface is covered by water...It's going to be a very long day...Florida Marine Patrol.
Old 03-24-2007, 01:14 PM
finestkind finestkind is offline
No doubt!!!!!!!!!! i had to learn the hard way, but luckly i got to the mooring early enough before i lost her!!! another couple of hours !! ARHHHHHHHHH!!! But make sure if on a mooring you have enough juice in your batteries!!!!! yes i do have scuppers but on the seafari there is a step down to the cabin where water likes to go and then drain thru the drain holes in the floor which then fills the bilge!! So now i have two pumps in case one fails which did happen to me as well on a two week old pump!!!!! never can be to safe!!!!!
Old 03-24-2007, 02:05 PM
when my 20 is done it will have 3100 gph for the bilge pumps..
Old 03-24-2007, 02:24 PM
mr sc
i gots sum pumps that i rig youz fer overkil too
bye sam
Old 03-24-2007, 04:44 PM
My Seafari has two automatic 500 gph pumps - one forward at the cockpit sole, and one aft, an 1100 automatic aft 3 inches above the 500, and a 1750 manual aft. I leave my boat in the water for 10 consecutive days twice per year. I came to my boat about four years ago where I had moored it stern in to the beach at low tide with maybe 4 inches beneath the keel, and found it sitting on the bottom 10 hours later. I had left the kicker motor down, which acted like a kickstand and kep the boat very nearly upright. BOTH my West Marine automatic pumps had failed, for the same reason - faulty float switches. (I now have Rule pumps) I ended up rewiring the boat and ultimately replacing the fuel tank.
The moral of the story: Make sure you're redundantly redundant with your pumps.
Fr. Frank says:
Currently without a SeaCraft
Old 03-24-2007, 06:48 PM
mr sc
bye sam
Ugh Sam, Is that there set-up for frog giggin' or Flounder
giggin'. Or is that just what you keep at the front door
of your FEMA mobile home
See ya, Ken
Old 03-24-2007, 09:13 PM
Got to be frogs, you need multiple prongs for flounder... Also looks like a Kel-Tec P3AT...I caught he!! finding mine!!
Old 03-24-2007, 09:54 PM
bigeasy1 bigeasy1 is offline
********Water in, bad---Water out,good.*******
I have to ask the same question as strick asked,Where did you get those nice vents,and are they metal?
All this,just for a boat ride
