Old 09-23-2007, 03:03 PM
edloh edloh is offline
Default Re: Almost had a heart attack.
Hello there,
These are all very good idea. When i was new to powerboat, David Pascoe website provided a wealth of information to get a boat seaworthy.
- seal the opening to the bilge (hatches, holes, cable entry)
- double bilge pumps, electrical and battery ( as mention above)
- for those with rear drain (install scupper)
- seal the big livewell in the back especially if not in use. This would provide plenty of flotation.
- bilge alarm
-etc
Old 09-23-2007, 09:23 PM
askipper3 askipper3 is offline
We are going to fill the livesell with high density foam- and seal it off completely. Should add some nice floatation.
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150
http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg
Old 09-24-2007, 11:37 AM
riprunner riprunner is offline
I have the same set up as Blue Heron. Float switches tend to go bad every couple years or so. You should check them regularly. I even keep a large hand pump in the boat just in case.
Old 09-24-2007, 08:42 PM
The livewell isn't a liability if it's set up right. I have a livewell pump controlled by a float switch mounted inside the well in a domestically fabricated (homemade) aluminum housing that prevents livies or sloshing water from interfering with the float switch. The livewell drain is plumbed to a through-hull fitting in the transom and the pump discharges overboard through a fitting on the starboard side above the waterline like a bilge pump.
The sequence of operation goes like this: Water enters the livewell through the drain. When the livewell gets full to within about two inches of the top, the float switch activates and pumps it down an inch or so. Then the cycle repeats. Works like a charm, even when the boat's rocking in heavy seas. As long as the lid's not open, the water stays in the well and below deck level.
I've installed some other plumbing that allows it to recirculate when the boat is on plane. I can go into more detail if anyone's interested. Maybe a post in Repairs/Modifications.
Dave
P.S. I use the livewell as a trash receptacle when I'm not fishing. Keeps the deck clear of the usual trash bucket. I just hate to see you get rid of all that usefull storage space when the livewell's not really the culprit in the sinking.
Blue Heron Boat Works
Old 09-25-2007, 07:41 AM
Wouldn't the pump ALWAYS be running? Because when the waterline goes down...more water comes in. (people in back)...........
Old 09-25-2007, 01:16 PM
Nope. It pumps down faster than the water flows in.
Old 09-25-2007, 02:52 PM
SCSeacraft SCSeacraft is offline
askipper3,
Do not fill that livewell with foam. I had the same idea back in 89' when we 1st reworked our seacraft and it helped to rot out my transom.Over the years small amounts of water worked its way into the well and slowly the foam absorbs this moisture,over time you get a nice "crockpot" effect in summer heat and the wood slowly absorbs the moisture through the fiberglass well.
when we finally cut the old foam out it weighed a couple hundred pounds with all of the moisture.
Donnie
Old 09-25-2007, 06:46 PM
What if you were to drill a hole in the bottom of the well...the water would go out if it gets in...it will be sealed though.
Also is the boat begins to sink water will come UP the hole...and lift the foam....rising the boat up. Right>
Old 09-25-2007, 06:48 PM
askipper3,
Donnie
Also is the boat begins to sink water will come UP the hole...and lift th foam....rising the boat up. Right>
Old 09-26-2007, 12:08 PM
LoveMySeacraft LoveMySeacraft is offline
I like the Rule computerized bilge pumps better than a float switch operated pump. Just my .02 LoveMySeacraft
