Dose anybody know what a 85 merc 175hp bruhes original lenght is when they are new. mine are only7/16 in long. also the date code on the starter is 4/12/79 i take this is not the original starter?
73 seacraft 80 merc my boat |
Probably not the original starter. I went to get my starter on my '91 Merc 150 rebuilt, and ended up exchanging it for an already rebuilt one off the shelf. It had a 1994 date on it, but worked just fine.
I can't help you with the brush length.
ok father thanks for the advice i will take it down to my local electrical repair shop and see what he can do.
i found the brushes on line but it dose not state what the lenght of them are sooo
Are you sure it is the brushes? What makes you think so? Are they corroded?
9 times out of 10 a starter fails because the armature is grounded to the commutator. |
when i compress the brushes inside the housing where the springs are the dont poke out that far when i release them. i have not run a ohm test thought the armatur to the communtater to see if i have a short there.
