Old 05-03-2008, 12:17 PM
manuelfadra manuelfadra is offline
Default electrical setup
Hi guys
Question should i connect the neg of the of the battery to the ttop Why my friend are scare of the lightings is that dangerous in a boat?
thanks
Old 05-03-2008, 12:24 PM
Default Re: electrical setup
NO NO, Not to the negative on the battery !!!
All metal should be bonded to a grounding plate
on the bottom of the boat.
IE: Bow rails, rod holders, Out Rigger holders, T-Tops...
You get the picture.
Usually 10 gauge tin coated copper wire to every locatation
mentioned above, then to the Bronze bonding plate.
See ya, Ken
Old 05-03-2008, 09:53 PM
BigLew BigLew is offline
Osmany,
You might want to check this out. this guy David Pascoe covers many subjects and is a good starting point in getting yourself educated as to how systems work the way they do and some of the pitfalls of the untrained attempts of well meaning boat owner/repairmen who try to do the right thing, but just don't know what they need to to do the job right.
Good luck.
Here's the URL: http://marinesurvey.com/yacht/Electr...AC.htm#Grounds
Plan accordingly!
Old 05-04-2008, 02:35 PM
But don't connect the engine to the bonding plate....???
