Old 11-20-2008, 06:11 PM
Trey1096 Trey1096 is offline
Default Re: Fuel Flow Meter/Gauge Questions
Just my $0.02, but I’ve got a LMF200 with a couple of fuel flow meters and I’ve never been able to get it to the point to where I trust it. The whole system has been back to Lowrance twice and the second time they sent me a new LMF200 unit. Each time they say, “Yes, it’s not working right, but we fixed it.” Then it still won’t read consistently.
I pretty much stopped fooling with it since I’m in the process of a repower.
My new engine is a 2008 225 Opti with a set of SmartCraft gauges. Does anyone have any experience with the SmartCraft fuel management feature?
Trey
Trey
'64 13' AeroCraft, 15 Rude
'74 23 SeaCraft, 225 Opti
'84 18' Winner, 150 Merc
The bitterness of poor quality lingers long after the sweetness of low cost.
Old 11-21-2008, 01:27 AM
I have the Lowrance/BRP I-Command digital gages and they seem to work well. The fuel flow and total fuel usage are calculated based the fuel flow/speed/throttle opening maps built into computer rather than an actual measurement, but generally seem to be fairly close to the old Flo-scan meter I've had for years. I have had occasional electrical gremlins with the Flo-scan meter (bad ground, bulb burns out, corrosion on connectors, etc.), so if anything I'd say the I-Command system is more reliable, although maybe not as accurate. When I start the motor after it's been sitting for a couple of weeks, the Flo-scan gage will jump up to 8-10 gph for a few seconds, like some fuel in the lines has evaporated and is being replaced, and of course the I-Command calculating system won't pick that up. The Flo-scan Totalizer generally seems to read a little higher and I tend to trust it a little more (except when the gage has been acting up!)
