Old 04-20-2010, 09:18 PM
Smitty46 Smitty46 is offline
Default Re: Little Console Work
Looks great!
When I finish painting my deck,the console is next.
I was thinking of wood but the starboard looks good.
Old 04-20-2010, 11:10 PM
makade makade is offline
SeaPlusPlus, If you'd rather teak it, I have that piece for you, its from a 18. Not sure if how much wider your console is?
Old 04-22-2010, 01:16 PM
SeaPlusPlus SeaPlusPlus is offline
Thanks for the offer makade, probably pass though, I still have the piece for mine, and could probably be cleaned up, but I think I'm gonna go with starboard.
Old 04-25-2010, 10:15 AM
Well I'm done for now. It could really use one or two more coats to make it lay perfect, but thats the beauty of varnish, just scuff it down with a white scotchbrite, then alcohol in 6 months and add an extra coat or two. All said and done I put 8 coats on, sanded with 220 and wiped with alcohol in between every coat. Then on the 8th coat I sanded half of it back off to level everything out more and did 3 more final coats that were sanded and wiped .
