...to complement my seacraft. came across a custom built wooden boat that im considering buying. its 8 years old, marine plywood (painted), white oak stringers, mahogany deck and engine box. could use a bit of cleaning up but its built soundly and rot free. the owner has all the cleats, lights, etc, it has a new rudder and prop, no engine, no transmission. i have very little experience w/ inboard engines. my question to you guys is how much will i be looking at for a motor and transmission? the boat is about 17 feet. also, how big (ballpark) of a motor does it need? lastly, considering i wont be using it much, is it a bad idea to get a used inboard? old, unreliable outboards are a nightmare (as we all know), are inboards any different? i know i can search the web and find some info but you guys are so knowledgable, it never hurts to ask. thanks in advance.
Got a picture?
I assume straight inboard? How many feet forward is the stuffing box? When you say it is painted, is it possibly skim coated in resin and glass then painted? I would think a boat that size would have a tendency to be wet and pound with a inboard to start so I would think a 4.3 might be the best compromise.
Thank goodness that in the scheme of things you are broke, powerlesss and inconsequential, because with the shortsighted alternatives and idealogy you have you'd be much worse than those you complain about. |
If you could post a picture it would help.
What is the layout - center console? runabout? What is the shape of the hull? What is the weight of the boat? |
boat does not appear to be skim coated, as i can see the "filler discs?" in the plywood through the paint. i can also make out putty/bondo circles where there are screws. its light, i bent my knees and gave a lift in the bow and raised it up a few inches. "filler box" is motor enclosure i assume, farther forward than a lot ive seen. has old school bench seat in front, motor box directly behind (right in middle of boat), then another bench seat in the way back. its a simple runabout. hull is similar to an old chriscraft, not much deadrise, wide bow, nice lines where transom meets gunnels. i believe it is designed for a straight inboard, just has two exhaust ports cut into transom, like i said im no genius when it comes to motors. i got a few pics on my phone, i guess nows as good a time as ever to try and learn how to post them. thanks
attempt #1 at picture [image]http://http://i1043.photobucket.com/albums/b432/justinnat1/woodboat2.jpg?t=1277123697[/image]
wow, im so surprised that didnt work.
Post deleted by 224466
i know pictures would help but i dont see that happening this morning. if i keep trying my computer is heading out the window. ill try again this evening.
[image]http://
i cant beleive this worked. im 28 years old so i really have no excuse for hating computers but... [image]http://
