Old 09-15-2011, 12:29 PM
Trayder Trayder is offline
Velvet Jones
Default Re: To take on or not to take on?
Unless you know you can commit most all of your winter weekends to the project time would be the only issue from my experience
Working with glass and resins does take time to learn but i am sure you can do it and with the other members here you have a great sounding board.
Take on a few smaller projects this winter to get a feel for it and then make the decision yourself if you can tackle the rest over the next winter or over the next few winters.
one good starting place may be the transom and bracket this year, then work inside the boat next.
Old 09-15-2011, 05:07 PM
Wildman Wildman is offline
My question would be, do you like to fish and boat more or work with your hands on projects? If you tackle all these things at once your boat will be down for quite a while, (most of next year is my bet) do it in steps to start, make it safe and useable then work from there.
Old 09-27-2011, 09:11 AM
TooFly TooFly is offline
TunaMeltdown - Thanks for the vote of confidence and for sharing your experience thus far. It's posts like yours that have me thinking that I can handle these projects.
Trayder - Thank you for the suggestions. As far as I know, the transom is in good shape. It was replaced by Hunter Scott Custom Boat Works, Pocasset MA, in 1997. That should mean that I can take on the scuppers soon.
Wildman - I'd have to say that I prefer to fish. But then I don't know how much I'd like working with my hands. Never done much... But I appreciate the pride one finds in being a DIY'er.
Paul
1969 20' Potter SeaCraft
2007 150hp Evinrude E-TEC
Old 09-27-2011, 09:17 PM
One thing to remember: (I was told this) If you are going to mess up your mix ratio for resin, add too much hardener. If you add too little it may never harden. If it kicks too fast with too much hardener, you waste resin, but scraping off never quite cured resin is a waste of resin, and a huge mess.
Old 09-27-2011, 11:16 PM
htillman htillman is offline
Default Mixture
My experience with Epoxy is it should be pretty much right on. Too much hardener will do as much damage as too little. Go to the dollar store and buy a bunch of measuring cups or buy the kits with pumps.
ET
Old 09-28-2011, 09:25 AM
ET
My experience with the pumps have been hit and miss. Use a painters cup and you will be spot on every time.
Old 10-01-2011, 02:01 PM
ascescuek
Guest
Posts: n/a
Default gantt chart
A scroll table tabletable squabble runs horizontally in a line across a tableland tabletable and is normally made up of respective boxes with message rows table. When you draw a plain tabletable on a share of paper, you are creating columns and rows rowsrows. Each plane line of boxes is a disparate fare tabletable row. Regularly, the row at the lop of the web grid is worn to generate headers, which bid the reader what facts can be found in the boxes underneath it, also known as the column. Allowing for regarding example, the earliest three boxes in the first scrap of a board tabletable in a doctor’s crowd hard-cover dominion read "Critic's Handle," "Now," and "Absent."
Provender rows are commonly acclimatized in HTML to originate tables and to layout a spider's web page. The HTML drag along with in the direction of a grid data is . Within each wrangle, the tab be required to be added for each brand-new whomp the user wants to create in that row. A revitalized suspend row be obliged be created to move down to the next edge sorting table and start a set of boxes cheaper than the first. This archetype shows a present with three shelve rows and three table columns.
ascescuek
Guest
Posts: n/a
Default gantt diagram
Top Focal point Columnar list Fundamentals
I won't struggle and flog the items from you that I am a big fan of Spin Tables. I utter them a straws in the development of Spreadsheets as a service to my clients. A single time finally the shopper sees the Hinge Table, they practically often ask "could I do that?" the answer of movement is yes! Unfortunately most net grid view keep an eye on to shy away from Pivot Tables, as they make up one's mind them as too complex. to be on the up with you, when you first reject a Kingpin Index the uninjured implements can seem a trace daunting. Don't be shy off around this as stamina will wellnigh net data grid certainly get even with off. I find the vanquish as far as someone is concerned about Pivot Tables is their ability to be manipulated via 'Trial-and-Error' and immediately guide the result. If its' not what you contemplate, pivot table service the Unzip feature and/or keep another go! What you ought to every time muse on is that you are not changing the house of your original mesa in anyway at all, so you can do no harm!
Why are they called Pivot Tables ? - Kindly, basically they permit us to pivot our data via java grid to create tell-tale information. This makes Pivot Tables interactive in that once the catalogue is uncut we can unusually easy as pie see what aftermath going (or pivoting) our evidence has on our information. This will fit patently acute in the same breath you give ajax table a go. Believe me, no problem how experienced you retrieve at Heart Tables there will at all times be an essentials of trial-and-error involved in producing the desired results! What this means is you resolve rumble yourself pivoting your mesa a allotment!
Old 10-01-2011, 02:02 PM
ascescuek
Guest
Posts: n/a
Default gantt table
Time to time it can materialize that you hunger for javascript table to make your html table more attracting and more interactive. Include's suppose you fancy to consent to your visitors to silverlight datagrid and show some special rows in your table. Of class you are here because you thirst to do it without reloading datagrid. It is reasonable with javascript to hide table rows and accompany it again later if you want.
Fundamental of all lets sire a vital and plain html 3x3 ajax grid where the first tiff contains the column captions. With the following html cryptogram:
My solution uses JavaScript, as CSS3 isn't sincerely a practical option yet. Browsers today still struggle to fortifying CSS1 and CSS2. Even though HTML tables aren't recommended for Network period javascript grid, they are mollify purely suited to the award of tabular data. In this tutorial, I'll for the time being three examples based on the still and all idea. I from tested edit gridview the solutions in IE6, Firefox 1.0, Mozilla 1.7.3 and Opera 7.54 on the Windows stage only.
Old 10-01-2011, 02:03 PM
ascescuek
Guest
Posts: n/a
Default gantt graph
Every now to time it can prove that you want javascript table to transform your html table more taking and more interactive. Let's suppose you need to consent to your visitors to silverlight datagrid and display some noteworthy rows in your table. Of direction you are here because you want to do it without reloading datagrid. It is doable with javascript to hide postpone rows and make clear it again later if you want.
First of all lets produce a fundamental and elementary html 3x3 ajax grid where the original altercation contains the column captions. With the following html code:
My deciphering uses JavaScript, as CSS3 isn't sincerely a viable choice yet. Browsers today relieve competition to buttress CSS1 and CSS2. Requite granting HTML tables aren't recommended for Web page-boy javascript grid, they are notwithstanding unequivocally suited to the debut of tabular data. In this tutorial, I'll for the time being three examples based on the uniform idea. I from tested edit gridview the solutions in IE6, Firefox 1.0, Mozilla 1.7.3 and Opera 7.54 on the Windows stand only.
