Old 10-15-2011, 11:15 PM
GodsReel GodsReel is offline
thanks a lot guys , gonna try and post a pic.
Old 10-15-2011, 11:17 PM
thought some of you might be interested in embroid work
Old 10-16-2011, 01:45 AM
Thats purty. How many inches of the back of the boat are in the water. At the rear corner from top of water to chine?
Old 10-16-2011, 09:23 AM
Very nice Paul!!! I'm betting the Dusky in the background "is green with envy" to even be in the same marina as your SeaCraft. Sorry....I couldn't help it.
Old 10-17-2011, 10:36 PM
seacraft 84, it is about 2 1/2 " without the transom livewell full.
Old 01-11-2012, 01:07 PM
csurf csurf is offline
Capt Chuck
I'm guessing that the "T" is to drain the boxes in the stern?
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
Old 01-11-2012, 02:02 PM
Originally Posted by csurf View Post
Capt Chuck
Transon Boxes & Rod Holders = NO water in the bilge
Old 02-01-2012, 05:08 PM
irish irish is offline
I have a 2001 SeaCraft20. I am thinking about adding scuppers above the waterline and above the floor so that water would run out if I got alot of water in the boat. The scuppers I have are self bailing but water does not leave very fast unless one is going forward, which may be tough to do if the boat was in the situation where there was alot of water in the boat. A consideration would be that if there was alot of water in the boat, would the scuppers then be under water and rendered useless? Any thoughts? These would really be emergency scuppers. Thanks for your input.
Old 02-01-2012, 10:21 PM
Default scuppers
I am thinking of adding above the waterline scuppers to get rid of water should I ever have several inches in the boat.With the scuppers I have( 2001SeaCraft20) the boat must be moving forward to get the water out with any kind of speed. AM I better off w a pump on the floor? I don't think it is as straight forward on the 20 as it is with the 23.
Old 02-04-2012, 09:51 AM
So you want to add scuppers above the deck to drain faster when there is allot of water, sort of like an overflow. If you're not draining fast enough and you think it might me dangerous, enlarge your current scuppers to let more water through. The bigger the hole more water drains out.
1980 23' SeaCraft
