  #61
Old 04-23-2012, 08:01 AM
Hey Fred, that sure brings back memories from when I rebuilt my console. I had no idea there were so many holes drilled in mine from previous owners, my brother counted over 180 after I took off all the hardware and "stuff". Oh yeah, do all you can inside the console while on the saw horses, after it's installed everything, even as simple as tie wraps, are harder to deal with laying on your back.
Old 04-23-2012, 10:11 AM
fdheld34 fdheld34 is offline
Thanks Jorge...I am getting there...you made some serious progress in the last couple weeks!!!!
Danny--I ended up going with upgraded windshield from UPD Plastics at 3/8" thick (as opposed to 1/4") and smoked..it was $230.00 shipped to my house...I will receive it in about 4 weeks. I am keeping all pictures so my son can look at them when he is older....yes he is a happy guy!!!
Don--I plan on doing everything and I mean everything on the sawhorses...I am over 260 lbs so it is hard for me to work on my back/side in confined spaces for a period of time.
-Fred
Old 04-25-2012, 09:36 PM
I was able to get 2 coats of finish on my console. Now I am starting to get the console rigged..before I install back in boat. I was able to get the starboard dash installed. I routed the edge to get a perfect cut against the console. Also, I installed a hatch and frame for console...So much more to do, including my new gauges etc. I plan on getting everything wired up prior to install of console!
-Fred
Old 04-25-2012, 09:39 PM
After routing the edges of the starboard, I installed the plexi wrap around on console. I still have some small pinholes on console I have to contend with...but might just leave..its just a darned boat!!!
Some pictures..... the boss and owner of the boat is pleased with the progress..he was unavailable for a picture!!!
-Fred
Old 04-26-2012, 05:40 AM
The console's looking good, Fred. What did you use for finish?
Dave
Blue Heron Boat Works
Old 04-26-2012, 09:37 AM
Thanks Dave...
I am using two part Interlux Perfection for everything. It is very easy to apply and the hull finish seems to now be pretty durable. I only used a one part primer and one part bright white poly finish inside console so I can see in there!!!
I have not advanced enough nor am I set up to use Awlgrip etc..
I just used my 3" brush on console to apply and tipped it....did not use a roller.
-Fred
Old 05-02-2012, 07:16 PM
I puttzed around in the garage last week and was able to get holes cut for gauges and switch panel. Now on to wiring gauges etc down the road..........I also received my baystar steering in the mail.
The owner of the boat decided that he wanted to save money on wiring so he started to untangle an old wiring harness I had from a mercruiser. We should be able to get some good usable wire after he is done!!!!
-Fred
Old 05-02-2012, 07:37 PM
I have a wiring harnes with a key switch that works on Merc's don't know if you can use it
Old 05-02-2012, 07:47 PM
Hi Jorge....I dont know what happened to the rest of my pictures..I deleted them!!!
I have a wiring harness for my engine..getting wiring ready for gauges and switch panel..thanks for the offer though!!!
-Fred
Old 05-06-2012, 06:05 PM
Today me and the owner/boss worked on getting the bimini top up...we also installed the binnacle and ran cables...All wiring is done for the switches etc and all I have to do is connect to bus bars and fuse block..Also, I have to install my baystar steering..I am slowing up due to having to fly back and forth to MS to help my mother and look after our 700 acres up there!
Attached pics, including pics of the owner/boss and some other pictures that the owner took as well!!
-Fred
