  #161
Old 05-30-2012, 11:49 PM
Dont' remember what year it is but it's not new but it was free to me but that's another story
And it's in a lot better shape than the one I had before
Old 05-30-2012, 11:59 PM
I love the grab rail that I have on my console It keeps people from grabing the wrong things and provides something to hold on to.
Now it does provide a challange in doing some kind of door for the storage on the left.
I plan on either flush mounting a garmin 740s and the VHF on the right side, although living in Miami I hesitate to put it there and it could go on the top so I can bring it inside after use.
Also the rail could get in the way of the Garmin unless placed in the right spot
But any ideas on what I can do as far as some kind of door for the left side storage?
Old 05-31-2012, 02:28 PM
ScottM ScottM is offline
Dieter Sprockets
Is there enough tubing protruding from the tee to allow a 45-degree bend upwards in the grab rail to move it out of the way?
Old 05-31-2012, 02:52 PM
that's an idea. will look today if it works
that's. why I come to this site
Old 05-31-2012, 04:14 PM
hugo hugo is offline
how about a sliding plexi door in some groove tracks.could slide to the right side.
Old 05-31-2012, 06:46 PM
I tried your idea today but the tube that goes all around the console is one whole piece.
Goes to show how well these boats were built. Today's boats would not go thru the trouble of bending 1 tube to fit all around the console it would be at least 2 seperate pieces.
What I will do is later take it to the plexi glass guy for a new wind shield ( since I cracked mine in the install) and have hime give me an idea or 2 for the door
I may try the sliding door but I don't think there would be enough space
Thanks for the ideas !!!
Old 05-31-2012, 07:08 PM
fdheld34 fdheld34 is offline
Jorge....looks like you have room to cut the rail leaving enough 0n the attached piece to fit a 45 or 90 degree fitting???
-Fred
Old 05-31-2012, 07:28 PM
-Fred
Yes i see what you mean but I don't want to cut for the moment
I still have time to see all the options and the way it is now it's on there and people can hold on with out it falling apart.
Worked on the trailer some and have to continue dialing it in after I visit the marine store for some parts
lets see if the CFO/Admiral/Wife gives me some budget to work with???
Old 06-02-2012, 04:48 PM
Here is the console when I got it
http://i22.photobucket.com/albums/b3...s/100_0851.jpg
It looks like it had plexi glass doors that spaned the console but I change it
I want to flush mount the electronics on the right side and have a "glove/storage area" on the left but the grab bar limits my choices.
Thinking I could do the plexi doors but just on the left side, I still have most of the teak so I would only need the bottom piece
Opinions???
I was also working on the trailer.
I eliminated the rear center roller and moved the bunks in so the it would support the hull and centered it also, I plan to get a piece that would protect the hulll with the rear cross member and attach it there.
Next I had already installed the battery switch and placed the batteries under the console and will finihed hooking up the batteries to the switch
I have an appointment to take the engine to have the lower unit worked on as it is leaking fluid around the prop shaft most likely the seals are bad
Then I plan to hook up at least one bilge pump and take it for a run just to see what happens.
Old 06-02-2012, 07:50 PM
red20 red20 is offline
Looking good
