Old 06-18-2012, 06:52 PM
kneedeep kneedeep is offline
try and make your cap follow the lines of the front deck where your toes meet the inliner,you want to be able to stand straight up against the bolster. you need to mark a line 3 or 4'' behind the front bulkhead across the top of the cap. maybe 8''on both sides of your center line
Old 06-18-2012, 07:09 PM
Originally Posted by jgrisham View Post
Mcgillicuddy, if, i'm correct you are on the west coast? Might not be cost effective to ship 3k miles.lol If you are close by PM me and you can come check out what I have. I am trying to toss out as much as possible so it doesn't create to much of a pile as I work. Point being don't waste time getting back to me.
Yeah, You're right never mind. Carry on.
Old 06-18-2012, 08:06 PM
jgrisham jgrisham is offline
Thanks for the pointer Kneedeep. I get what you are saying, I definitely want to be able to lean against the rail, makes for a much safer feeling boat. Did you router the edge of the PVC board? What kind of release agent did you use? The stuff they sell up here isn't completely smooth.
Old 06-18-2012, 09:47 PM
I have absolutely no experience with I/O's, and I am a little overwhelmed prospect of re powering.
I was kinda thinking I could find a used GM vortec engine and buy a simple harness/pcm and drop it in, Is this doable?
Also the engine mounts seem to be hollow and kinda flexible kinda like they have been compromised. What would be the best way to go about fixing this problem?
I bought the boat without an engine so I did not get to learn by disassembling, but how is the engine actually fastened to the mount?
Old 06-18-2012, 10:40 PM
yes,i think i used a 1/2''roundover bit on the inside edge. used a mold release wax/paste. you could use plywood or mdf with formica for a one off mold. the pvc board i had was smooth on one side wood grain on the other. as far as the i/o goes i can't help you that was the first thing i got reed of. outboards for me. in my boat the motor mount for the i/o was about 4-5 2x6 stack on each other then glassed in. seems to me your giving up a lot of space with a i/o cover,leaning post and a cc. or are you going with a pilot house?
Old 06-19-2012, 07:46 AM
Kneedeep, I kinda like the idea of being able to repower for 2k or less, Pretty hard to find decent outboard for less than 5k. I definitely won't be doing the waltz on board, but it should still meet my needs. Do you think I should cut the whole mount out and start new, or should I cut the top off and pour in seacast or such? Is the motor lag bolted, or where studs/bolts placed when the mounts where set?
Old 06-19-2012, 06:11 PM
You don't want to use an automotive engine in an I/O for a number of reasons. First, automotive starters and alternators aren't ignition protected. Second, the cam/valve timing is different on a marine engine. You should be able to find a decent used marine engine for under $5k.
The engine mounts to the inside of the transom assembly and to the forward motor mounts. The forward mounts are height adjustable. Do yourself a favor and buy a factory service manual for the engine and drive.
Dave
Blue Heron Boat Works
Old 06-19-2012, 06:33 PM
j i would take a die grinder with a 3'' cut off wheel and cut 1 1/2'' down from the top all the way around it and remove the top layer. see if it's solid wood ,if so add a new top layer and re glass. if it's wet keep removing it. the mounts in my boat were lag bolted with ss lags. you may find the need to move the center console a little farther forward to offset the wt you removed from the bow and maintain your waterline and may pick up some space behind the leaning post too
Old 06-19-2012, 11:24 PM
Thank you both. Blue Heron, how can the timing be different? I can definitely see needing ignition protected components however. Thanks
Old 06-20-2012, 05:45 AM
... Blue Heron, how can the timing be different?...
Less overlap on the exhaust valves so it doesn't suck water back up the exhaust. I'm not much of a motor head, that's just what I've read.
Dave
