Old 05-24-2011, 09:15 AM
Highway12 Highway12 is offline
Default 23 cc inboard prop size question
Just purchased a 23 cc 350 Mag MPI 300 HP. The boat is way under propped. Can anyone recommend the correct prop size for this setup?
Old 05-24-2011, 05:21 PM
MarkR MarkR is offline
Default Re: 23 cc inboard prop size question
tjudgejr-
Mine is a '75 Sceptre inboard, Marine Power 350 - 4B Carb 260HP
16 x 16 cupped
2700rpm - 20knts (most economical cruise - I think)
4200rpm - 30knts
Old 05-24-2011, 06:45 PM
joshz joshz is offline
On my old 23 inboard cc I started with 16x16 cupped. This prop would not get the max wot so I went to a 16x15 cupped. This prop got the max wot for the engine. My numbers were 22kt cruise and 31kt wide open with a carbed 350 merc. Hope this helps, I played with a few and this was the best for that boat.
Outermostangling Charters
Old 05-25-2011, 07:20 AM
Thanks guys, Sounds like 16 x 16 would be a good staring point.
Old 05-25-2011, 05:19 PM
The reason for the cupped edges is it helps reduce the noise generatoed in that tunnel.
Old 05-26-2011, 07:28 AM
Thanks The cup also adds pitch which should put my RPMs right where they should be. I was testing a 16 x 16 yesterday and blew the raw water pump impeller so I never got to full RPM to tell if it was correct or not.
Old 12-06-2012, 03:30 PM
Default Repower 23 inboard with 240 Yanmar
Anyone know what prop to start with?
Old 12-07-2012, 08:54 AM
aldo aldo is offline
I'm running a 16x15 cupped as well on my 350/260hp inboard with throttle body injection.
I experimented with quite a few others but get the best numbers with it.
Old 12-10-2012, 03:29 PM
Default inboard diesel Yanmar 240
Does anyone have a recommendation on motor mounts?
Old 12-13-2012, 10:45 AM
Gary Hill Gary Hill is offline
I have a 16 x16 prop and 315 HP Marine Power engine And tweaked it here in Tidewateer VA to turn 4600 RPM.
GARY
76 SEACRAFT CC INBOARD
