#241
20’ SeaCraft SF with bracket
Performance Data 6/16/13 Calm seas. 40 Gals fuel, one person, med load. 14 ¼ X 17” 3b Yamaha SDS Reliance Prop. RPM GPH MPG Spd Knts. 1000 .7 8.3 5. 1500 1.3 6.8 8. 2000 2.2 4.8 9 2500 3.3 3.8 11 3000 4.3 4.7 18 3500 4.9 5.1 22 4000 7.2 4.3 27 4500 9 3.9 30 5000 13 3.1 35 5500 16.5 2.4 39 6000 19.5 2.5 44 I still need to do some playing with engine and prop. Want to get a little more speed out of her. :-) |
#242
As mentioned before. That 5k RPM slot looks good.
I bet you could go to a 19pitch and stay pretty close with your numbers.
The trouble with trouble is it starts out as fun. (Mark Twain) 1989 20ft C/C SeaCraft/Tracker 1989 200 Merc BlackMax. |
#243
![]() Quote:
Try a four blade. And will try a 19". I like what you are saying. ;-) |
#244
Nice clean job there young man.
#245
I agree! Beautiful work!
1975 SF18/ 2002 DF140 1972 15' MonArk/ 1972 Merc 50 http://i833.photobucket.com/albums/z...photos/SC3.jpg |
#246
the four blade should help lift the stern at lower speeds also !! maybe even try out a 5 blade.... ;-) get speed lift and load carrying..
80 23 SCEPTRE TWIN 135 MERC OPTIS 75 20 Master Angler 115 Mariner Tower of Power RUSTY PARKER http://i92.photobucket.com/albums/l2...eyemailtag.jpg |
#247
Perfection.... Nuff said
78' / 20SF / Merc XRi Black Max 150 |
#248
![]() Quote:
I am happy with the bracket height, it is down low enough that I get a good portion of the flotation values, I can still mount lights, thru hulls, etc, thru the main hull and it is a good height for boarding. But I feel the engine could go higher, so I will raise it a notch. How is your project progressing? I thank everyone for their kind comments. It appears as if the wind Gods may have changed their minds, the first forecast for this w/e was ESE 15-20knts, little too sporty for my taste in this boat. Now that has been revised to 11-14knts, if that is the case, I'm ouuta here!! Final touches going on, TUUCI Top, etc. Last is the cooler, spear, rods, fins and TM/LLL II. :-) Last edited by Caymanboy; 06-19-2013 at 06:45 AM. |
#249
By next Friday I will be ready to hang the engine!
Thanks for the info....I have been dreaming of bracket heights. |
#250
![]() Quote:
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
