Old 04-07-2014, 07:46 AM
fatcat01 fatcat01 is offline
removed some poor glass work as well
Old 04-07-2014, 07:50 AM
may be hard to see but some laminated wood mounting block was poorly done. when I cut this one open water poured out!
Old 04-07-2014, 07:52 AM
on a better not, this is a section of the decking....solid!
Old 04-07-2014, 07:56 AM
started cutting out the decking and foam....the floor is soling but I wanted to check out the foam to see how wet it was and to really get a good idea as to the integrity of the flooring....and to install some chases to run the new rigging
Old 04-07-2014, 07:57 AM
surprisingly, the foam was bone dry.....no signs of moisture
Old 04-21-2014, 11:35 AM
unfortunately not much progress but did cut out the stringers where they attached to the transom...only sign of moisture was around the drain....notice the black marks where the drain was
Old 04-21-2014, 11:38 AM
when I cut out part of the center/ keel stringer it was saturated but solid...if there is such a thing. should I be worried? the lower pic shows the section of keel stringer I removed. again, it is solid but not mush. Thoughts?
Old 04-23-2014, 12:10 AM
FLexpat FLexpat is offline
I think it isn't that big of a problem - I remember reading a thread here where someone discussed this - IIRC the thought was that the glass on the center stringer is thick enough that the wood is not really needed for strength - it could be a hollow stringer and work just fine. Based on that, I just let mine dry out when I discovered the same thing - wood fine but pretty damp and very thick glass.
Old 04-23-2014, 07:51 AM
thanks for the input Flexpat....that's kinda what I was thinking too....
Old 04-23-2014, 08:15 PM
Fatcat had the same issue with my I followed it back maybe 18" or so where I found clean dry wood ?cut it on a 45 and potter puddled a new PC back in and reglassed it Back in
