#131
Sweet!!
#132
Taco marine part # v21-9613 rigid vinyl. Go with the higher end Seastar. Like how you incorporated the concrete tubes in the mold. First class as always!!!! Keep up the great work.
#133
Really impressed with your workmanship! Everything fitting like a glove and neatly rigged.
#134
I layed up another mat and 1 layer of 1708 on it and let it set up over night .
![]() I Popped it off the mold and it was relatively easy ![]() ![]() this is where it got tricky I set the circular saw to just under 3/4" and made some rips. I then got in with the flat bar and chiseled away without damaging any gelcoat. once I got a small area of gelcoat opened it went easy, One plastic wedge under and it popped right up ![]() ![]() ![]() I cleaned it up with the air nozzle then took it outside for a wash and cleaning. I then took my air trimmer and cut all the excess off. I dropped it in the front part of the console and it fits pretty good. I little more trimming and I will be glassing it into place. ![]() ![]() ![]() ![]() I got the template out for the forward bulkhead and cut it out of the of the 1/2" panel I layed up and it fits pretty tight. might have to do a little trimming to get it back a little bit. ![]()
36' Yellowfin 1972 20' seacraft 140 suzuki http://www.classicseacraft.com/commu...ad.php?t=18607 |
#135
I decided to put an anchor locker door in so I made a mold for the door and the acess panel at the same time. it was easier to cut the template for the flange and make it 1/8" bigger with some luan.
I also made a box for to go over the fill and vent hose. I will drill 2 holes through it for them and mount it down to the floor to keep stuff from falling on top of the tank. ![]() ![]() ![]() ![]() ![]() gonna do one more layer of glass on the anchor hatch then pop it off. I cleaned up the transom with the flush cut bit in the router, I then took out the grinder and cleaned the transom down for some glass I hand sanded the corners and put a radius on the corners to make the glass roll easier. ![]()
#136
coming along great man...
#137
This joke will never get old!!!! AHHHAHAHAHAA
50 Ton, '72 SC 20 |
#138
Progress has slowwed with summer time work and fishing. Gonna go at it hard i a couple weeks. It is also giving me time to clean the garage and get more parts in that i need. Anyone interested in spliting a barrel of poly resin? You would have to come to my house to pick up. I only have 5 gallons left and i figure i need 25-30 more. Pm me if you are serious and i can tell you prices
#139
Would be glad to split that poly with u but im in fl
#140
I am ready for one myself and would split it but it would be hard for me to make it up there. If there is anybody up here on the board that makes trips from u to nc/VA let me know and I would be glad to compensate the driver
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
