Old 08-16-2015, 04:23 PM
Default Impeller change 383 Stroker
Has anyone out there done a raw water impeller change on a Mercruiser 383 stroker engine? If so any tips or tricks? FYI it has a serpentine belt and it looks like you have to take the pump off .
Thanks,
Old 08-16-2015, 07:35 PM
Jeswick Jeswick is offline
isn't the water pump/impeller in the outdrive ?
Old 08-16-2015, 11:26 PM
FLexpat FLexpat is offline
All Bravo drives, like the Volvos, have engine mounted raw water pumps. Alphas have outdrive mounted raw water pumps. I don't know how to change the Merc Bravo raw water impeller; mine is a crankshaft mounted Johnson pump - I don't know how to change the Merc Bravo raw water impeller.
Old 08-17-2015, 09:48 AM
bobbert bobbert is offline
Just a thought, have you checked the raw water intake??? Up here we have problems with stuff growing in the intakes.
Old 08-17-2015, 01:04 PM
This may help...
https://www.youtube.com/watch?v=UxLfF2abE_o
Old 08-17-2015, 10:17 PM
I have no knowledge. But I have factory manuals. But I bet you do too. If not, let me know.
Old 08-19-2015, 07:37 AM
No problems...just doing a 1st time preventative maintenance change.
Thanks...saw this before, but I was hoping for one showing a serpentine belt (video) like what I have.
Haha...believe it or not I do not have the manual. So any help would be appreciated.
Old 08-20-2015, 11:10 AM
Ok what exactly is the model? I'll look tonight
Old 08-21-2015, 08:06 AM
383 mag mpi...bravo 1 1.65r
Old 08-23-2015, 09:36 PM
I finally found my manuals. They don't cover the 383, but they cover the 305-377 CID engines. I suspect it is the same but I don't know for sure. It does cover the 350 MAG MPI.
I think I have a gen ? cool fuel? Mine looks like this
https://www.youtube.com/watch?v=eZYJq746awc
Pretty much you have to detension the serpentine belt and pull the whole pump. It looks like the procedure is pretty similar, brass versus composite housing.
my manual goes from 0M300000-1A299999
If you know which housing you have I can scan pages. I suspect your engine and mine would be the same.
