There's a thread going about an entire top cap needing to be record which got me thinking about my cap up by the bow where I want to reinforce it for a swivel rod holder. The boat is a 1972 20 CC. My cap is solid glass except for the bow area where there is balsa or plywood. I want to avoid removing the entire cap so in the picture below here's my plan: cut the top cap about two feet forward of the gunwhale rod holders on each side,then cut the two vertical pieces right near the bow about half way down then remove that section of the cap to be able to turn that piece over and remove the old core and add new/better coring that will better support the rod holder. I'm pretty comfortable glassing as I've done the deck and transom and the engine has yet to fall off. The picture is old, when I redid the deck but it's all I got now that the boat is shrink wrapped. Does this seem like a good plan?
Is the plan to remove the rub rail, cut the deck from gunnel to hull joint above the rod holders then split the deck from the hull for this operation?
Remove rub rail but not cut from deck, cut from the top piece of the side where the rod storage is.
If you did that how would you glass the back side and under the cap? Glassing upside down is not fun.. What about outlining where the firing is on the topside. Being careful to stay within the core. Cut the top skin off and recore from the top. That way you still keep the structural parts of the cap intact ..and you only glass from the top. When you remove top skin.. Keep it so you can glue it back to the core material.. It will save you some glassing.
I figured there would only be two places (one on each side where I cut to remove the bow section of the cap) and I could use some tape to hold the wax paper to the underside to keep it up. Or something similar like a piece of waxed melamine screwed in from above to hold the glass up that way. I thought about cutting it out from the top but if really like to beef that area up with like 3/4" material. If I did that there would be a raised area up there.
Im having a hard time visualizing, any chance you could draw some lines on that picture to show where you want to cut?
http://www.boatbuildercentral.com/ ![]() my rebuild thread: http://www.classicseacraft.com/commu...ad.php?t=22090 |
i wish i could shine. lets see if i can explain a little better. Looking at the picture. The two vertical supports just forward of the small hatch, i want to cut those in the middle horozontally. Secondly, where the gunwhale rod holder is on each side, forward of that 2feet, just above where the shaddow is on the port side, cut up that small piece and then across the cap and same thing on the other side. This will allow me to remove the forward 4 feet or so of the cap while leaving the rest intact. If someone has the technology to minuplate the photo to add lines where you think i'm talking about, i'll let you know if thats what i'm thinking. Thank you for the help.
I cut the section of the cap off on my 20' hull in the rear to do the transom not the front like you mention. Some things I found when I did mine- 1) Like mentioned by Martin it is hard as hell to get to the back sides and even harder to glass them. the wax paper thing works good and I have done that several times to hold the resin in place. It will help it kick off faster and give you a more uniform finish. 2) Make sure you taper back the edges both ways far enough when you do glass it back. When I did mine I started with an inch both sides and the guys up here recommended me going further and I changed it to 4-6" each side and it gave it a better surface to bond to over a larger area. 3) It will be much easier to core the cap off and up side down but a pain to put it back on.
If it was me, I would consider just cutting out the top of the area you want to do and remove the core from the top then replace it and build it back. The down side of doing it from the top tho- 1) you will have a difficult time removing the core material if not rotted well. 2) if you keep the bottom skin in tack you are limited the thickness of you core you can add back. If you want a thicker core you will have to cut threw the bottom skin and use a backer to hold the new bottom skin while you re-make it then you can add the thicker core above it once you re-make the bottom skin lower. If you do it from the bottom side with the cap off you can cut the bottom skin off then add as much thickness as you want with out trouble. 3) The refinish on the top has to be worked much more to get that fine finish and then gel coated or painted. from the bottom you don't have to worry as much with the final finish under the cap but you do where you splice it back on. So either way you will have fine finish work and paint to do. I would have to say over all if you are going to do a small area for a rod holder it may be less work and easier to do it from the top, but if you want to re core the whole nose section and re-work all of it, may be better to cut it and pull it off and glass it back down. I always like to do cap work from the bottom with the cap off but getting it off is a lot of work. Also you can think about removing the whole cap but that's a ton of work due to the rear area is stuck down with tons of potter putty and the top of the stringers glued down as well as the front section. Being you did the floor the way you did you cant pull the liner out no longer probably. If it was a master angler where the cap comes off easier with out the liner it wouldn't be so bad but an sf model with a glassed in floor you will be cutting something no matter how you go about it.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
Since you've already painted the decks (I think you did, didnt you?) I would just go through the top.
Run a circ saw with the blade depth set to cut just through the top skin, and cut out as much of the bow area as you dare. Leave enough of an edge to grind back so you can glass the original skin back on. Once you remove all the core, replace it with whatever you want, plywood, coosa, solid glass whatever. Glass and fair the top skin back on and then repaint it again. Should be able to blend it together ok. Zachary
Zachary [SIGPIC][/SIGPIC] |
I believe you know this is going to be a PITA. However keeping on task with the objective I would work from the bottom, cut the section out as best you can that is soggy, provide a reasonably smooth surface to attach 3/4 marine plywood that you can epoxy (thickened) to the underside of the deck using a notched trowel ( you may have to use pieces that you can fit in there and dowel or plate join them together) then over lap the seam with another piece of ply screwed and glued. If the deck has curve to it you can use 1/4" wood that conforms better to the deck and laminate it to desired thickness. if you feel the need reinforce with gussets' or just coat with epoxy. In the end you will have a solid deck that should be more than adequate for the support you need for your rod holder. If a BFT rips the deck off let me know where you were when you hooked him and I will be there trying to catch his brother LOL
