  #31
Old 04-11-2016, 11:25 PM
Would you happen to have a photo of a V- Notch P/U and screen?
Vezo, Part II
Old 04-12-2016, 07:27 AM
Vezo, Part II
No screens for me. Let the filter do its job.
Pm me your number and I`ll text one to you.
Old 04-13-2016, 07:16 PM
I like 3/8 ID aluminum tubes with an upside down V in the bottom of the tube.
This allows flow if you pick up a leaf of drop a piece of foil in the tank.
I have not posted many pics in a good while now.
I have a battery back up case on my phone and the port is only for charging.
Grrr. I took it apart when I first got it and broke a cheap tab so I am afraid
of doing more damage.
Tank is out and fill hose as well. The coffin is wet so a new one will be made
next week as friends are visiting from Vahmont this weekend.
Zig only wants a Sailfish, Swordfish, and a Wahoo.
No problem.....hah.
Old 04-14-2016, 04:47 AM
shine shine is offline
Moderator
I am considering making some tanks from fiberglass (an entirely new topic ) but I am looking for a supplier for aluminum tanknow fittings. Fittings will be welded to mounting plates that will go on the glass tanks. Can anyone point me to a fittings supplier? Need pick up, vent/fill, and a sender plate.
Old 05-01-2016, 10:38 AM
I`ll ask the folks at general sheet metal.
Bill`s grandfather worked w the CG to develop the standards of production to abyc back in the early 60`s.
Old 05-01-2016, 04:47 PM
Moderator
Thanks will contact them when the time comes
Old 05-01-2016, 06:05 PM
You do know e 10 melts glass tanks right?
Old 05-01-2016, 06:11 PM
pelican pelican is offline
not all "fiberglass" is created equally - meaning,not all fiberglass is effected...
Old 05-01-2016, 09:25 PM
Resins have come a long way in 50 years.
As have fibers.
Much like composites.
I`m sure Shine is way ahead of me, but others read these posts and I try to
make folks think and evaluate choices as I have learned the hard way thinking
I was ahead of the curve.
You have much to offer here as well.
I think Don Herman`s resin is a cool 1,000 clams per barrel.
Isophthalic or some such stuff.
Novolac epoxy or vinylester might also work well.
Cheers,
GFS
Old 05-13-2016, 10:28 PM
As we dig,we find. Seems the slacker deck needs some putty to fill some voids
between stringers and the deck.
