  #41
Old 11-30-2016, 06:38 PM
Originally Posted by badhabit View Post
. . . I will try to get better pictures this weekend starting with the motor all the way down . . . l
Here are a few tips on the kind of pictures you want. Motor height is important for best performance and good handling . . . you want the Anti-Ventilation plate up on top of solid water when you're up on plane at cruise, with motor trimmed up/out as far as you can normally trim it without porpoising or ventilating during a sudden hard turn.
Best way to measure AV plate height is to place a straight edge up against bottom of boat, extending back along side of motor AV plate. (I used a section of aluminum angle, held against hull with a bottle jack.) Then trim motor so AV plate is parallel to the straightedge. My motor is parallel to keel when the I-Command gage reads about 45% trim, where 0% is trimmed all the way down. Once motor is parallel to keel, stick a scale on it and measure distance from straight edge to bottom of AV plate, as in first pic below.
Second pic is what my motor looks like when looking over the transom. (You may need to put some black electrical tape on top edge of AV plate, because it's very hard so see that white plate in white water!) I added the SE sport fin on AV plate because I have a very aft CG due to 30" setback bracket and a motor that's ~ 130 lbs heavier than the boat was designed for; the fin, along with the 4B prop provides much needed stern lift that lets me plane at about 12 mph and helps keep running angle flat.
3rd pic is what motor looks like when it's too low. (Most dealers mount the motors too low because they either don't know any better, or just don't want customer complaints from blowouts/cavitation and don't care that the extra drag costs speed and wastes fuel!)
4th pic shows AV plate at correct height. Because the water flows up after it comes off the transom, motors need to be much higher when mounted aft on a bracket. I had to add a 3" setback jackplate and raise my motor/AV plate up to about about 6" above keel as shown in last picture, to get the AV plate above water. A motor hanging on the transom will typically want to run somewhere around 1-2" above keel. Depends on prop because some props can run higher than others depending on design and amount/location of blade cupping. In my case, getting the motor height correct allowed me to run a better, more highly cupped prop that increased top speed by 2-3 mph and reduced cruise fuel burn by about 10-15%, all while maintaining great handling and good low speed planing performance, so I think it was well worth the effort!
BTW, I think you're losing some lift on those trim tabs that slope up at the sides. I spent my engineering career studying fluid flow in jet engines, and water will tend to run off the sloping sides of those tabs! A vertical turned down "fence" on the outer edges like on the Bennett Sport tabs would stop that and increase the pressure on the bottom sides of the tabs. Some swept wing aircraft use similar wing "fences" to prevent transverse flow along the wings that reduces lift. Might be worth riveting some aluminum angles to the outer edge of the tabs to see if it improves tab performance!
Old 12-01-2016, 12:21 AM
kmoose, on sea trial back tank was empty and the big tank had about 15 gal in it. it was flat calm and it ran great.
good stuff coming up here, keep digging...too fine a craft , got's to dial her in.
15 gallons will have little to no slosh factor in a 6'x2.5' box centered under the deck. 60 or70 gallons might.
This goes more toward your bow lift concerns, but I don't recall reading what model of prop you are running. Can you respond to that? perhaps youre trim angle is off, but maybe you have a bowlifting prop design too. Pics look like it has considerable rake. That will usually mean exagerated bow lift. On a higher mount it can also cause greater instability. this would be exacerbated by trimming too high.
I think Bushwacker also makes avery good point about that tab shape. wide flat suckers would be preferable me thinks.
Good luck with that sweet Seafari
Old 05-29-2018, 07:07 PM
badhabit badhabit is offline
I wanted to update you guys on this problem. I think gillie and kmoose are the winners. we put a stingray hydro foil on and 350 lbs in the bow. yesterday we went 30 nkm out oc md. we had the center tank full and not much in the back tank. they were calling for 3to4 6 seconds apart and I would say that is what it was. on the way out the thing ran better than it ever did. if it leaned at all it would come right back up and we were very happy. on the way in it was a different boat,if it started to lean it just kept going further and you had to slow down for it to come back up. so it looks like when the tank is full it cant slosh around and when it is not full and the boat starts to lean a little bit all that fuel goes to one side and makes the boat lay over on its side.
