Old 06-26-2017, 03:10 PM
Jonhybrid Jonhybrid is offline
Default SeaMount Marine Bracket
I've been looking to add a bracket to my 20MA. It has a 2012 Yamaha 150 4 stroke on the back and it seats stern heavy. I'm in the Tampa Bay Area and found a company up here called SeaMount Marine Products. I called them and they seem very knowledgeable. My Question is has anyone used them or know any info on them. Any info would help thanks
Old 06-26-2017, 03:16 PM
Colin Mattson has made two tanks for me and some custom made aluminum "emergency drain pans" for my A/C air handler. Good people, been around forever.
Old 06-26-2017, 03:37 PM
If it's stern heavy now, it will be much more so with a bracket. Even if you use a bracket with the maximum possible flotation (a Hermco), you're CG will be shifted aft when up on plane, so min planing speed, ride and load carrying ability will be worse than it is now. If you haven't already read it, I'd suggest you check out my post on the pros & cons of brackets.
Old 06-26-2017, 04:49 PM
Colin and Robyn Mattson are great people and do very good work. I've had them build fuel tanks for both my SeaCraft and Bertram. Both are "Vee" bottom tanks with a second or third pick up that is 1/4 lower than the engine pick ups. I have an extra hose and priming bulb on the "low" pick up and every six months or so I pump a little fuel out in case I buy or develop any water. Colin said send me a drawing of what uyopu want and I'll build it. He will build an oversized "floatation" bracket if you want him to. Kicker bracket, dive ladder etc., - no problem. I think the best option in the Bay Area, if you don't go with the Top Rated Hermco Fiberglass unit.
Old 06-26-2017, 08:54 PM
Make the tub as large as you can get it for flotation
Old 06-26-2017, 10:36 PM
Default Stern Heavy MA
Jonhybrid-
By all means you should check out Bushwacker's post on the pros and cons of adding a bracket. He has one and is candid about the changes he experienced. I suggest you also check out my post of Estimating CG Shift with Heavy Engines (about 9-24-16). You can judge how much CG shifted with a 4 stroke and how much more it will shift with the 4 stroke on a bracket.
Old 06-27-2017, 08:09 AM
Thank you everyone for for the information and from what I gathered I'm going to raise the motor and get the AV plate out of the water and look into an AV plate fin and maybe a stern lifting prop. Sounds like the bracket is going kill performance on the cruise n top end for me.
Old 06-27-2017, 08:34 AM
215robert 215robert is offline
Recently had a bracket made by Colin for my 20sf, work is impeccable and completed on time!!! Be prepared for him to adjust designs without consulting you as he knows more about brackets than we do...In regards to flotation I have compared mine at rest to some photos of other manufactures brackets and do not see a difference with a 135 Opti...
Old 06-27-2017, 09:10 AM
Default bracket
quick pic
Old 06-27-2017, 09:34 AM
Although the amount flotation in a bracket at rest may determine whether or not a boat will self bail at the dock, the flotation advantage disappears when you're up on plane. The much more important metric is one that you can't see, i.e., what moving the motor ~30" further aft does to your boat's CG! Motor weight is a large part of that, so lightweight 2-strokes have a significant advantage for use on a bracket!
CG location/boat balance is the single most important factor affecting your boats performance, as that will determine min planing speed, how well it rides in a chop and the boat's tendency to porpoise.
