Old 11-25-2018, 07:38 AM
classictwenty classictwenty is offline
Default Coosa board for transom replacement
Have any of you used coosa board when doing transom replacement on a 20' SC console and if so, any suggestions? Thanks
Old 11-25-2018, 11:06 AM
SeaPlusPlus SeaPlusPlus is offline
Lots have, i did it on 20SF restore and am using it on my current 23 restore as well. Plenty of examples if you use the search feature!
If you have any specific questions feel free to ask and I'd be glad to share my experience.
General suggestions:
  • Use the 26lb Bluewater density, not the 15lb. 28lb density Carbon Core (same type of material, different company) is a good alternative
  • Use either (1) 1.5" sheet or (2) 3/4" sheets epoxied together to get 1.5" core thickness.
  • Use luan or cardboard to make a template of the transom to use to cut the Coosa
  • It cuts and shapes easily, so any tool you use on wood will work for Coosa
  • Take pictures and document it here!
Old 11-25-2018, 04:45 PM
Many thanks!
Old 11-26-2018, 12:16 PM
caboman22 caboman22 is offline
I used a single sheet of blue water 26- 1.5 " on my 23cc -1974
rock solid...
