  #71
Old 01-27-2019, 10:16 PM
Kraken Kraken is offline
Rainy day but made the best of it. Molded up three hatch covers. I took some pics showing the process. I’ll pop them tomorrow.
Old 01-30-2019, 02:46 PM
Crispy167 Crispy167 is offline
kraken,
what type modeling clay are you using - air dry or non drying? thanks for showing the process, hopefully i can recreate some of your great workmanship myself! project is looking good!
Old 01-31-2019, 10:42 PM
Originally Posted by Crispy167 View Post
kraken,
Found some non drying at a craft store. The stuff leaves a blue residue that is hard to wash off. The clay I got at fiberglass Florida worked the best.
Old 02-01-2019, 10:17 AM
CoreyTrx CoreyTrx is offline
I use the Super Sculpey original in beige. It's available at the craft store. It works really well.
Old 02-27-2019, 09:44 PM
I’ve been trying to decide on paint or gelcoat. Pros and cons for both. The primary use for this boat will be diving and spear fishing. It will be trailered. So it will need a real durable finish on the deck, cap, and bottom. The belly band can be paint. Are there better options?
The cap has all the holes filled and the bait well glassed on. Ready for fairing and maybe gelcoat. The outside of the hull is ready too. Just need to finish up the deck / transom wall with a radius and tabbing. Also need to mold up the front hatch cover. I’m getting close to sending it off for final finish.
Did some work on the console I bought at Marine Connection in Stuart. It was only 3/16” thick and had to be reinforced. I added 1/2” coreing and some 1708. I will also install a door and foot rest.
Old 02-28-2019, 07:51 AM
Can't wait to see her all shiny!
Old 02-28-2019, 08:19 AM
KNZ911 KNZ911 is offline
Looking god Scott. Let me know when you are done with your table.
Old 03-01-2019, 05:16 AM
Has anyone successfully used Plexus MA310? I’m considering using it to bond the liner to the hull. I may also use it to bond the cap to the hull. It requires little surface preparation, fills and spans large gaps, fails after FRP, it’s flexible, and only costs 25$ a cartridge. It’s commonly use in new boat construction. Is there any reason I would want to pull the cap at a later date? Would bonding it make it more solid and perform better. Will bonding the cap reduce the creeks and pops?
<https://www.jamestowndistributors.com/mobileportal/show_product.do?pid=4882&familyName=Plexus+MA+310+ High+Strength+Plastic+Adhesive>
Old 03-01-2019, 05:24 AM
Soon. Finishing up the last of the structural glass. I did get the hatches to work with the curved surface.
Old 03-01-2019, 09:31 AM
"I’ve been trying to decide on paint or gelcoat. Pros and cons for both. The primary use for this boat will be diving and spear fishing"
This is the same use as Moose's boat. Check out his bre-build, I think he went went an interior that could be easily repaired versus a real pretty and shiny one.
