Old 05-16-2020, 09:25 AM
Default Yamaha 30
I picked up a Yamqha 30 for $50 for my skiff project. I took a chance on it and I've thrown away 50 on other things. Yesterday I got around to doing a compression check and all 3 fired at 125 psi. Not bad at least the upper is in good shape. Bad news is the the lower unit is shot.
Need paint it and decals to clean it up
Now I need to find a lower unit the fins are broken in 2 different sections
Any ideas were to look or someone have one laying around?
Old 05-16-2020, 10:49 AM
JohnC JohnC is offline
I have seen miscellaneous parts at Sailorman in Ft Lauderdale but it's really hit or miss. You could call them. Boats.net and a few others online retailers sell parts if you think it's rebuildable. Lower unit seals & gears are not crazy expensive.
Old 05-18-2020, 08:17 PM
Is the lower unit lube clean doesn’t it tur freelyif it’s just the fins they most likely can be welded (AIM s alloy welding in Lauderdale does great work at very fair prices
Old 05-18-2020, 09:23 PM
the lower is shot internally and the fins are broken on both sides but I have the broken pieces.
going to take it to AIM to see what they can do $ and then if its not to bad get it rebuilt.
Seems like there are not many on the market for reasonable dollars.
Old 05-21-2020, 07:22 AM
Best of luck! If it can be fixed he can do it or will tell you
