Old 12-21-2021, 01:15 PM
25" four stroke
Original console will either be narrowed or replaced with a narrower one if I can find a decent one
Tank will be 3/16" aluminum, ~ 46 gallon from Speedy Tanks (Atlantic Welding)
Old 12-21-2021, 03:57 PM
Originally Posted by KenB View Post
Why transom to 27"? For XL motor? Or jack plate?
...and 2 more inches of freeboard.
Old 12-27-2021, 02:54 PM
Cockpit depth question; The specs for a 20SF say minimum 20". I get 19 1/4" near the factory deck drain. What dimension are others getting?
Old 01-09-2022, 01:26 PM
Would anyone with a 20' SF be willing to get the above cockpit depth dimension please? And please add whether you have raised your deck and if so, how much? Thank you
Old 01-10-2022, 08:02 AM
I can check mine at lunch and get back to you. 73 unmolested floor. (I haven't started cutting yet.)
Old 01-10-2022, 01:04 PM
The strap is approx. 1 foot in front of the floor drains. 19-3/4" from deck surface, not gutter.
http://www.classicseacraft.com/commu...1&d=1641834259
Old 01-10-2022, 01:14 PM
Thank you sir!
Old 02-11-2022, 06:36 PM
Tank should be here Monday. Console is ordered, C&M in Fla 38" square outside of flange. Transom is in, 2 1" thick pieces of Coosa. Deck is out. Stringers will be tied-in to transom, gutted, re-poured, and raised. Question; What are pros and cons of foam outside the stringers as shown? My 23' was not like that.
Old 02-12-2022, 05:44 PM
Nice you aint fooling around there.That looks like a sloppy foam job whom ever did it prior to your acquisition. Myself I would leave the foam out and just re foam the inside of the stringers...it's just more weight and another place for water to get trapped...I've seen where the the underside of the cap has been foamed in some boats. as long as you leave enough room for the getting to the wiring and hardware. Looking forward to your progress and thanks for loading your pictures straight.
Old 02-12-2022, 06:44 PM
Thanks Strick. I agree on those points to omit foam there. After a 10 hour round trip drive today I scored what will (I hope) become my leaning post/cooler/tackle center combo. I would never pay retail for a new one but I felt if I didn't fly and buy this morning I would miss this. I'll have pipe-work built to include a 3" riser. This puts the 2" cushion top at about 30". Sorry about the sideways pic.
