Old 04-26-2002, 01:19 AM
Reel Smoker Reel Smoker is offline
Default Re: console sizes
OK, Im confused here.Is the small console the one that comes with the seat built in.Correct me if im wrong the large console does'nt come with a seat but has the large door that gives you access to the bottom of the console? I was told that the hatch underneath the console was used to hold a toilet? Thanks RS.
Old 04-26-2002, 01:53 AM
Scott Scott is offline
RS
Your right about the consoles....The smaller one has the seat molded into the console and I believe is a little shorter in overall hieght. Take a look at Bill Sirotnak's pictures. The larger console does have a large door in front of the console that opens and exposes the entire backside of the dash and inside of the console. On that door is a molded in seat. (I also received with my boat a flat door with no seat....which I like alot as it gives me a little more room up front). In the console I believe that there were different setups. Again mine, 1976, does not have a hatch that exposes the bilge area. I just have a flat deck inside the console. I'm planning on either moving the fuel tank a little bit forward into that area or putting a removable hatch in there for added storage. Right now its a 30" x 30" hole thats not being used....I'll fix that [img]images/icons/grin.gif[/img]
Hope this clears up you question
Scott
Old 04-27-2002, 10:18 AM
Thanks Scott,I have the big one, which I cut in half that way I can open the top part for quick access inside.I use a cooler in the front of it as a seat.Prior to cutting the door I would have to move the heavy cooler ,now its alot easier. RS.
