Old 07-15-2002, 10:18 AM
Default Re: whitehawk or FELLOWSHIP, help me!!!
HA BEN
DOING A TRANSOM IS NOT REALLY THAT HARD IT DOES TAKE A LOT OF TIME AND EFFORT ESPECIALLY IF YOU ARE GOING TO USE THIN LAYERS OF PLYWOOD. I USED ¾ “ MARINE PLYWOOD IF I WERE TO DO IT AGAIN I WOULD USE 3 PIECES OF ½”. I USED THE WEST SYSTEM AND USED THE SLOWER HARDENER. IF YOU DO THE WORK IN THE SHADE YOU WILL HAVE PLENTY OF TIME TO APPLY THE RESIN AND CLAMP AND SCREW IT FIRMLY INTO PLACE. THEN ALLOW YOUR WORK TO DRY AND DO THE SAME PROCESS OVER AGAIN. I CAME IN FROM THE INSIDE BY REMOVING THE RUB RAIL CUTTING THE CAP ABOUT WHERE THE ROPE GIZMO IS AND THEN REMOVING THAT WHOLE AREA BACK THERE. YOU CAN SEE MY PICTURES ON THIS SIGHT UNDER KEN MCGOVERN 23’ MY HOME PHONE # IS 954-680-0493 YOU CAN GET ME AFTER 6 PM WITH ANY QUESTIONS YOU MIGHT HAVE I DID MINE WITH NO HELP AND REALLY DIDN’T NEED ANY. I ALSO ADDED EXTRA SUPPORT FROM THE CENTER LINE TO THE TRANSOM AND FOR THE SPLASH WELL. I ALSO REMOVED THE LIVE WELL FROM THE TRANSOM AND MADE ONE AND MOVED IT FORWARD. ALL IN ALL A LOT OF TIME AND PATIENCE.
FELLOW-SHIP [img]images/icons/wink.gif[/img]
