Old 09-04-2002, 08:22 PM
JohnB JohnB is offline
Default Re: dry weights new 23cc vs old hulls
kajroxygurl,
450 pounds would be about the weight of a motor. Maybe the tracker numbers were dry with a motor on. You would have a hard time puting 450 pounds of extra class in a hull that size.
JohnB / 23' SeaCraft
Old 09-04-2002, 08:36 PM
kajroxygurl kajroxygurl is offline
It does sound fishy and maybe it is including the engine weight. The brochure says under the specs that "weight , boat only : 3100 lb." I get the feeling that since they were advertising each different model as a package that they were including the engine in the weight. At the least is was certainly misleading. The package price for the 23 CC was with a 200 Mercury/Mariner and was advertised at$17,995. Sure wish a new 23 was that price now.
Old 09-04-2002, 11:46 PM
Reel Smoker Reel Smoker is offline
I thought the 70's 23 were around 4000 lbs? maybe I heard wrong.I'll ask a friend tom he has a 71 ,23 and had it weighed without the motors.RS.
Old 09-05-2002, 10:58 AM
John R John R is offline
I'm not sure if it's true with boats or not but the term "Dry Weight" for many motorized devices is total weight less fluids (fuels/oils/etc) and that may be the same in that case. They may have included the base engine in that which was probably around 350-400 pounds at the time. The few older SC and other boat brochures I've seen (and some new stuff) usually indicate hull weight or weight no engines...
Surf and Boat fishing for
Striped Bass
Old 09-05-2002, 12:31 PM
Scott Scott is offline
Hookedup
Like kajroxygurl I've been told the original weight for my 76-77 hull was 2650 lbs. Somewhere there is a thread that was started about this topic and one of the guys on the site had original literature for this year (76-77). I'll see if I can find the link and put it up here.
Here is that link.... 1976 Specs
[ September 05, 2002, 11:38 AM: Message edited by: Scott ]
Old 09-06-2002, 01:57 AM
Runco Runco is offline
Factory brochure 1985 Sceptre boat only 3300#
Old 09-05-2002, 07:18 PM
My 1988 brochure which said the 23 CC weighed 3100 lbs. also listed the 23 Sceptre at 3300 lbs. Must have been making the boat the same as in 1985 since the listed weight is the same. The 20 CC is listed in the same brochure at 2100 lbs. which is 500 lbs. more than the 1978 20. Since every model in 1988 seems to be 400-500 lbs. more they may be including the engine weight just as JohnB says. I don't see how they could have possibly made the 20 500 lbs. more than the 70's models were.
