Old 11-20-2002, 12:14 PM
Matt1121 Matt1121 is offline
Default Re: cleaning hull... help fast!!!
Tom-
I use a water-downed version of 3M fiberglass rubbing compound . Try that first and be sure to keep the buffing pad wet with the product. Once you're done with the compound, follow-up with Starbright's Teflon marine polish ( you'll need to put on 2 coats about a week or two apart). Stuff is expensive $20, but is well worth it..I use it on my truck too.
If that doesn't work, break out the really fine wetsand paper that someone else mentioned previously. Be ready to sand until your arm falls off.
