Old 12-09-2002, 02:11 PM
AlexT AlexT is offline
Default Re: New Member, First Boat
Concensus here is that hull quality is good-- maybe not quite as much glass as the older boats, but a solid hull. If there is any difference it is likely the fit and finish and the quality of the componants like cleats, wiring, etc. From what I have seen of the new boats all this is pretty good. Certainly lightyears ahead of Mako (another Tracker/BPS brand)
Old 12-09-2002, 02:28 PM
threegills threegills is offline
I understand solid glass is the way to go, but now there are very few even "high quality" boat builders using solid glass in their cores. Only ones I know that are not using some kind of "high-tech composite" is regulator. Contender has balsa cores, yellowfin is composite-foam like the new seacrafts.
Still, wish there was a 27' old seacraft model. My 25' just seems like a 23 with a swim platform.
2000 25', Twin 175 Johnsons (carbed)
Old 12-09-2002, 02:45 PM
Brian Rice Brian Rice is offline
There are 27' footers floating around. Good luck with your new boat.
Welcome to the site.
Old 12-09-2002, 02:47 PM
Finster Finster is offline
Here good luck [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] http://www.projectboats.net/descript...ified.htm?1121
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 12-09-2002, 03:26 PM
John R John R is offline
http://www.theboatzone.com/gallery/27rawbar
Surf and Boat fishing for
Striped Bass
Old 12-09-2002, 04:04 PM
Trayder Trayder is offline
Velvet Jones
<font size="2" face="Verdana, Helvetica, sans-serif">Contender Balsa Cored????
The decks perhaps, but certainly not below the waterline. I do not think above either but I am not 100% I would check but my 25 Contender is under shrink. The deck cap and deck is cored but not all Balsa, some balsa here some marine ply over there ad foam core inbetween [img]images/icons/wink.gif[/img]
Old 12-09-2002, 05:55 PM
Please forgive the ignorance, but I'n no boat builder. On the contender website there is a link for the "process"
Here it states in #1 (post gelcoat application of hand laid fiberglass,balsa coring, strake reinforcement) does not look like they are working on the deck or inner liner,
#2 states that the stringers are foam cored (not solid glass, which was my point)
#3 says the inner liner is made with a pvc core sandwich fiberglass construction.
So were is the balsa?? from looking at the "process" it seems that it's somewhere below the waterline.
Not to say that contenders are not great boats. I have a friend in Puerto Rico where 5-7 seas is a good day. Even though his cuddy cabin-deck joint is coming apart and the inner wall of his deck-transom joint is coming apart. He swears by the boat. I've been on it in 5-7 running around 20 knots and we could not keep the boat in the water. We would get airborne on every wave. Re-entry was nice and smooth though. Even though the boat made a bad squeeking noise I've never heard
Contenders are great boats. They should just be a little heavier, same for all boats made now. Which is why people love older, heavily glassed boats that weigh a ton. that is what you want out there.
