Old 12-09-2002, 05:55 PM
threegills threegills is offline
Default Re: New Member, First Boat
Please forgive the ignorance, but I'n no boat builder. On the contender website there is a link for the "process"
Here it states in #1 (post gelcoat application of hand laid fiberglass,balsa coring, strake reinforcement) does not look like they are working on the deck or inner liner,
#2 states that the stringers are foam cored (not solid glass, which was my point)
#3 says the inner liner is made with a pvc core sandwich fiberglass construction.
So were is the balsa?? from looking at the "process" it seems that it's somewhere below the waterline.
Not to say that contenders are not great boats. I have a friend in Puerto Rico where 5-7 seas is a good day. Even though his cuddy cabin-deck joint is coming apart and the inner wall of his deck-transom joint is coming apart. He swears by the boat. I've been on it in 5-7 running around 20 knots and we could not keep the boat in the water. We would get airborne on every wave. Re-entry was nice and smooth though. Even though the boat made a bad squeeking noise I've never heard
Contenders are great boats. They should just be a little heavier, same for all boats made now. Which is why people love older, heavily glassed boats that weigh a ton. that is what you want out there.
2000 25', Twin 175 Johnsons (carbed)
Old 12-09-2002, 06:02 PM
sorry, the day we ran out it was more like solid 3' waves. Saw the typo after i posted
Old 12-10-2002, 12:43 AM
Trayder Trayder is offline
Velvet Jones
[QUOTE]Originally posted by Trayder:
[QB]Threegills-
Contender cores above the waterline, not below. Just confirmed with Contender. If you look at the process you mention on the site they are adding the coring to the hull sides ABOVE not below the waterline. (I am not sure you realize the boat in the picture is on its side)
Original SeaCrafts used Foam cored stringers, do you feel as though this is a bad thing?
I strongly disagree with your opinion that a heavy boat is a better boat, having looked at and test ridden Regulator 26's and Jupiter 27's and an older Intrepid 26 (the lightest of all 4) in my boat search I still fell I made the best choice with my 25, ride wise. It is unquestionable the fit and finish on a Regulator, Intrepid and a Jupiter is superior to that of a Contender. As for your friend's Contender coming apart I do not know how he drives or what he has run into but unlike most boats Contender glasses the Deck cap to the hull and inner liner: Dave Pascoe, The surveyor, ( Dave Pascoe's Contender 25 review ) did a review on a Contender 25 years back. He even states the hull bottom is solid glass, the resin used is Vinylester. In reading his unbiased review or taking a look at mine or the 12+ Contenders I know of up here and have run on I feel it would take a wave yeilding a chainsaw to break the deck cap joint on a Contender. Your friend must have met that wave or have one really messed up boat
Old 12-10-2002, 10:40 AM
thanks for the clearing up there, trayder
again, excuse the ignorance. can someone tell me how the new seacrafts are put together and the pro's and con's of this "high-tech" process.
Not too keen on the (PVC based Airlite foam) or that bonding stuff that they use. Where and why do they use this stuff?
is it weaker than glassing? I've never felt a shudder or anything after coming off a big wave.
what should i be looking for?
Old 12-10-2002, 12:47 PM
Velvet Jones
Threegills-
Most issues with a fiberglass boats arise from improper bonding regarding core materials or water intrusion into a core material. There are of cours other issues such as: osmotic blistering but I will not cover that here.
Back in the late 50's and early 60's the first fiberglass boats came out to market from companies like: Hatteras, Pearson, Cape Dory, and many more. These boats had solid laminates, multiple layers of plyester resin and fiberglass cloth.
Solid hulls are very heavy, many tmes too heavy to be very efficient. Now, not only were the hulls of these boats solid glass, they were also reinforced with fiberglass coated plywood for bulkheads, stringers, transoms and the like.
It would be very difficult to make an efficient outboard powered boat with this type of building technique. Although... there are manufacturers that have, Ocean Master is one such builder.
In order to make a more efficient boat the use of core materials came into play. The core material takes the place of multiple layers of glass and strenthens the hull while not bing as heavy as a solid multi layer lay up.
Where the core material meets the glass is where issues tend to take place. Sometimes it is just unproper adhesion and the layers of glass will seperate from the core material rendering the boat severly damaged. Other times, most often, water gets into the core, from improperly sealed screws, thru-hulls, etc. The water actually causes and chemical reaction with the resins and the glass seperates from the Core. Most often the water gets trapped between the core and the glass. If the core material is wood it will rot, if it is a composite it may absorb the water and/or continue the delamination issue.
How does one avoid issues with a cored fiberglass boat? You have the right train of thought to avoid hulls that are cored below the waterline. I am not saying all boats that are cored below the waterline should be avoided, they should definitly be scrutinized by a surveyor. If a thruhull weeps water into the core material it could be a very costly repair.
To avoid problems with most of todays boats with a cored transom, deck, hull sides, etc you have to make sure you seal all holes. The best way to do this is with thinned out epoxy. First drill your hole, clean it out, then apply a thinned out solution of epoxy. This epoxy will seep into the core material and will ward of water in the future. You are not done here, do not forget to use an adequate marine sealant when inserting the fasteners. The sealent is the first line of defence where as the epoxy is the last ditch effort protecting the core material.
If drilling into something covered with gelcoat, do not forget to countersink the hole a tad, this will prevent the unsughtly cracking often seen around stantion bases and screw holes.
Also, one can not simply screw into core material like wood. You will need a to thru-bolt whatever you are mounting or add a backerplate. Problem often arise when people mount things improperly to a cored surface.
Now as for different type of core materials: We could go on for many pages. People like to avoid plywood, I disagree, wood is excellent if you need a strong solid mountable surface. The disadvantages are: if improperly sealled it will rot and it is still very heavy.
The composites: Nida-Core , Divinycell , Kledgecell Balsa, Airex , Balsa (a wood but it is supposed to suck up the resins when used to prevent rot) each have their own characteristics but you can not screw into them like marine plywoods, you need to through bolt.
In my 20CC restoration I am utilizing 3 different types of Core materials. Marine Ply-wood, Nida-Core, and ATC Core-Cell. I feel as though each core matrial has its own place with in the boat.
Marine ply, for the transom and stringers. Transom for strength as long as the holes are properly sealed and the stringers for strength and weight. I wanted any weight I had, down low. The Nida-Core is for the deck, it is very strong and has fantastic sound dampening charachteristics. The Core-Cell is for the hatches and various custom componants, engine shroud etc.
Now there are many opinions on all of what I wrote above so please do not take above as the way it is, it is just the way I feel and how I like to do things. I did not even go into the different types of resins, Epoxy, Polyester, Vinyester, and so on.
Old 12-11-2002, 01:16 AM
trayder, thanks for the info. i'd love to tak on a restoration one day. (need to find the space and time)
I'd love to get a 27' Seacraft and redo it as a one level center counsel. Mount a braket and put some outboards. Maybe that boat would run better with a diesel under the counsel.
Trayder, thanks. How is my newer Seacraft put together though. can't find much info short of going to the plant. website doesn't help much.
i wanna know if i have something that i can keep for the long run. or is there something inherently wrong with the manufacturing process that would make it better for me to just sell and get a better made boat.
i realize that this is a classic seacraft site, but when i start the 27' restoration we'll talk about that.
trayder, give it to me straight. i this boat gonna last or fall apart on me. (just kidding)
Old 12-11-2002, 01:51 AM
Velvet Jones
Threegills-
This site is for anyone with intrest in SeaCraft Boats new or old. Anyone is welcome [img]images/icons/smile.gif[/img]
I do not think your boat will fall apart and I am sure it is one of the best designs out there. I am embarassed to say I can not comment on the construcyion of the new SeaCrafts as I do not know what there current construction methods are.
I am headed down to FL tomorrow and will find out and post with in the next week or so.
I certainly would rest easy and you should know you have a fine boat.
