Old 05-13-2002, 07:11 PM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Weight Distribution
Steve,
We don't really store much up front - 1 18# anchor with maybe 250' of line, life jackets, and 6 medium tackle rods.
Alex,
No water up front. I have a bilge pump up there because of the bow-down attitude. The aft pump doesn't see any action while at rest.
JohnB,
I saw pictures of your boat in other discussion topics (very nice by the way) and noticed that your boat sits very level, even slightly low in the stern, just where I would want mine to be. My fuel tank goes as far forward as the cabin door and back about maybe 18" beyond the storage boxes that the helm and passenger seats are on. My feeling is that the tank is in fact set farther forward to compensate for the extra weight of 2 V-6 outboards. Both batteries are in the transom boxes.
Let's put it this way, the transom corners at the chine sit maybe 1" below water.
Old 05-13-2002, 07:44 PM
Scott Scott is offline
Hi Scott .... Its Scott [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img]
Welcome
Do you just have one large tank??? Is there anyway you could slide it aft a little to change that balance point. I know in some of the older boats , mine included there are no bulkheads for the tank .... so in theory you could slide mine forward or aft. How much water pools...I mean If a 150 lb person jumps on the stern does that fix the problem??
Now you might have a live well or two in the way ..
Just a thought!!!
Old 05-13-2002, 07:47 PM
JohnB JohnB is offline
Scott ScottM,
I just looked at where my gas tank is, and going to the back,
It is almost to the live well (maybe 3-3.5 feet back) from the
storage boxes. I believe your tank is mounted further forward
than mine. A good test of this theory would be to run most of
the gas out of the boat and see if the front end comes up.
The picture of my boat is with 1/4 tank of gas. When it is full,
it is just about level with no one in it.
Hope this helps,
JohnB / 23' SeaCraft
Old 05-13-2002, 08:00 PM
capesams capesams is offline
SCott M:
I was just going through some more paper work that I have and it seems you are right about the tank being way forward due to the two out boards. like the other scott say's your going to have to slide the tank back aways to take care of the problem . In the other spec.s i'm looking at the tank starts behind the seats and go's to the well in the back. What I am finding out about seacraft is that alot of them were ordered because there were so many different options one could get. that the boat yards couldn't carry them all. this is why so many are so different from each other.
[ May 13, 2002, 07:02 PM: Message edited by: steve ]
Old 05-13-2002, 08:01 PM
Dieter Sprockets
Scott - thanks for the suggestions. Just one large tank, 144 gallons. There is a transverse stringer behind the tank that prevents you from sliding it back without doing some fiberglass work. I figure the 225 Evinrude is 450(?) pounds, and a 200 not much different. When my father and I (150 and 175 lbs, respectively) stand in the stern, the boat sits proper.
JohnB - thanks for the idea. I guess I am looking for an "easy" way to correct this, but it seems to me that the easiest would be to either do some glass cutting and move the tank aft (I have about 2 feet between the tank an in-deck bait well) or get a smaller capacity tank to get that weight off the bow.
Old 05-15-2002, 03:47 PM
Briguy Briguy is offline
Scott M,
I have the OPPOSITE problem you have. Since my '78 23 CC has 2 Suzuki 4 strokes, my stern sits a quite low. I am considering moving my tank FORWARD. I carry 150 gal's of fuel and am considering chopping 2 1/2 feet from the rear of my tank(it's 8 ft long)That would lower my capacity to about 105 gal's. Pleanty since I have the 4 stroke motors. I am curios of one thing. Could you do me a favor an measure the distance from the transom to the rear of your fuel tank for me. That would be a great help in estimating the success of my project. Thanks in advance!
Capt. Brian
Old 05-29-2002, 07:41 PM
Dieter Sprockets
Briguy,
Sorry I took so long to get back to you on the measurements. The aft edge of my tank is 34" from the splashwell door, give or take a couple inches. I didn't lift out the in-deck bait well to get an exact measurement. My splashwell is only 14" deep to give you a better idea as to where the tank really sits in relation to the transom. Good luck on your project and kepp us all posted as to your success.
