Old 03-08-2003, 09:55 AM
barnacle barnacle is offline
Default Re: New Evenrude unvieled at Miami
The Evinrude E-Tec Engines are a DI Two Stroke. It uses 50% less oil then current DI engines and 75% less then current carb. 2 strokes. To get this oil savings e-tec oil must be used along with a EMM that a dealer must program to let it know its using e-tec oil. THe E-tec also puts out 80% less carbon monoxide at idle then current 4 stroke outboards. It is also whisper-quiet thru out the rpm range. With fully-stratified fuel burn you get start up within one revolution. The 90 e-tec is is 100 lbs lighter then the current 4 strokes in the same hp. range. Plus the engine has such heavy duty parts along with tight tolerance's there is no break in. Full speed out of the box. The smaller ones will be out around July and the Bigger ones by 2005.
